Question about Vacuums
The stitches on bottom side are loopy. Do I change the tension by moving spool to higher or lower number on dial?
  • Vacuums Master
  • 5,481 Answers
Have you run a length of stitching with different color threads for the upper thread and the lower? Since the upper tension appears to be too loose, turn the tension knob to the right by 1/2 a number. This is a lower number (on my machine); so you'd go from 5 to 4.5. (It works just like most plumbing; turn right to tighten and left to loosen.) Then run another run of test stitching.
You may also need to check the lower tension but only as a last resort. There is a set screw that adjusts this; turn to the left to loosen and right to tighten (1/8 of a turn at a time). On one of the machines I have used, the bobbin case is easy to remove. For that machine, the test is to put the bobbin in the bobbin case and check what happens when you dangle the bobbin case by holding the thread. The thread should move when pulled but shouldn't pull more thread out of the bobbin when the bobbin case is dangling.
My sewing machine manual explains this adequately. However, I found better pictures in a volume called the Singer Sewing Book. Similar pictures are available here: http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . This is from an Extension Service site.
I hope this helps.
Posted on Mar 22, 2011
  • Cindy Wells Mar 22, 2011
    Whoops, I turn the dial to the right and the value at the dot increases so I go from 4 to 4.5. (I'd quickly looked over at my machine and forgot to check where the dot was relative to the digits.)
    Also rethread your machine to make sure the top thread is being properly held at the various pressure points.
    I hope this helps. I do apologize for my initial error.
    For a vertical tension knob, imagine turning your head and hand to your right so that the right/left directions hold. (The numbers are increasing as the knob is turned downwards.)
    (My household has several machines, two completely mechanical, one computerized with mechanical tensions and one completely computerized. I usually hit the manual for each machine and we keep the manuals in the cases.)
How do you adjust the stitch length
Did you get your answer yet? There are dials on your machine...the one on the lower right near the bottom of the machine is the length dial. You need to get yourself a manual if you don't have one. You can email me if you want more info, good luck!
Aug 30, 2014 | SewShop.com Singer Model 920 Futura II...
I own a singer 14sh654. Bottom stitch really loose,don't know what to set any of the dials at to make it work right. The top stitch is neat tight bottom all over the place
Hi. Loose stitching underneath means you need to increase the upper tension. Try just a little at a time, using scrap fabric of similar weight to what you want to sew.
Aug 19, 2011 | Singer Vacuums
Sewing basic stitch is good on right side of fabric but looks like a wavy line on reverse
Hi. Chances are your upper thread tension may need to be adjusted, increasing it by very small amounts at a time (say one tenth of one whole number), see if the stitching on the bottom improves. Another possibility is that the bottom fabric is moving around. Try pinning top and bottom together with straight pins set at a right angle to the stitch line. A third possibility could be lower thread tension set to tight. If the lower tension screw is all the way in, this is likely your problem.
Aug 19, 2011 | Vacuums
My Singer portable (#6202/62120) keeps stitching nicely on top, but the bottom stitching is all knotted up! It's driving me crazy! I have tried everything. Any help would be greatly appreciated....
The bottom side is effected by the TOP tension. First make sure the top is threaded correctly. Best thing to do is completely unthread it and then thread it again. Then check the tension and make sure it is not too loose. Check the needle to make sure it is inserted correctly and not bent.
Once you've done that then you can take a look at the bobbin tension and make sure it isn't too loose too. Make sure the bobbin is in the case correctly, wound correctly and that the bobbin case is completely inserted right. You will hear and or feel a slight "click" when it goes in correctly,
May 24, 2011 | Singer Vacuums
I'm new to sewing. It did not come with an operating guide and I find the stitch settings really confusing I would like to know how to set it to do a basic straight stitch for a simple dress pattern....
Look for the row of straight vertical lines. This is the straight stitch. There will also be a number dial for stitch length. Use a piece of scrap to find the length of stitch you want. Make sure you have the bottom feed lever or button activated. This will operate the textured plates that come up from underneath to move the material forward or reverse. Also, make sure you drop the presser foot lever before you start. Hold both threads, manually lower the needle to the first stitch starting point and use the pedal from there on. When you press the pedal, you can let go of the threads.
May 14, 2011 | Vacuums
I have an expression 2038 and the stitching has suddenly changed so that the top stitching is quite good but the underneath is loose. I have the tension on 4 and have a new straight needle and good quality...
If the bobbin thread is too loose, remove the bobbin spool AND carrier.Thread the thread through the tension clip on the holder in the normal way. Hold the thread and lift it. If the bobbin slides down, tighten the small screw 1/8 turn clockwise, until you can lift it with little or no sliding.
May 07, 2011 | Vacuums
HAVING A PROBLEM WITH MACHINE JAMMING UP AROUND BOBBIN AREA WHEN TRYING TO FREEHAND EMBROIDER IT STARTS OFF OK THEN QUICKLY JAMS UP HAVE ADJUSTED THE FOOTPLATE SO THERE ARE NO TEETH
Check your tension first by sewing a wide zig zag stitch. Does the top of the stitch and the bottom look identical? The sides of the stitch should look like a hole where the thread disappears to the other side, with no extra thread from the other side coming through. It also should lie flat and not be puckering in the middle. When it looks identical and no puckering the tension is correct. Use the same type of material and thread you will be using for the embordery. The bottom side of the stitch is effected by the TOP tension. The top side of the stitch by the BOTTOM tension.
Are you stretching the material you're hand embordering with a hoop?
The dog feed needs to be totally down and if your machine has an adjustment the tension on the foot should be lessened too. (not all machines allow for that adjustment).
Last but not least make sure you have the right needle for the job and material.
Jamming up in the bobbin area would most likely be from the top tension being too loose but also make sure the material isn't getting pulled down in by stretching it with an embordery hoop. Do use a presser foot... a wide clear one is best.
Apr 26, 2011 | Vacuums
Jc penny model 1710 sewing machine, the stitching isnt tight
You do not say if it is the top stitches or the bottom stitches for the bottom tension, check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
For the top stitch, tighten up on the tension adjustment on the front of the machine which looks something like this:-
images?q=tbn:and9gctmqnuzdetdofn3rmptgx4d6h3wsbbewgyursvcfmpbxpewspjy
Apr 11, 2011 | Vacuums
I have a Janome 8048. Here's my problem: As I sew I notice that the stitches on the top of the fabric look the way they should on the bottom side and when I take the material off the machine and flip it...
I haven't sewn in years. A sewing machine has a tension control on top and on the bobbin. If the intersection of the top and bottom threads is not in the middle of the sewn material, you have to adjust your tension.
In your case, what I think you are saying is that the stitch on top is just a straight line and on the back it disappears into the fabric.
To correct this, lower the top tension by loosening the tension adjuster on the thread where the thread loops around the small pulley.
Also, you could tighten the tension on the bobbin by slightly tightening the small screw on the side of the bobbin.
Gary
Feb 21, 2011 | Vacuums
I have an Elna 745 serger/overlock machine. Whenever I'm doing a double cover stitch hem, when I'm at the end, the thread release lever does not release the thread. To release it, I have to cut the...
There are two methods to release the cover stitch with sufficient slack in the thread. Since you are using the thread release lever, did you set the Brown tension dial to zero? Before changing the tension, you have to first lower the needles to their lowest position in the fabric with the hand wheel and then turn the hand wheel backwards to bring the needles to the highest point in the cycle.
The other method may work better for you. Bring the needles to the highest point in the cycle and lift the presser foot. Then slide a thin object (a sewing ruler, for example) between the presser foot and the feed dogs and pull the needle thread towards you. Cut the needle threads Then pull the fabric away from you before cutting the looper threads.
Both of these options are described on page 98 of the manual, which is available from Elna. The current link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst_Book_745_%28E-F-G-I%29.pdf . Pictures for the second method are available here: https://www.seamwork.com/issues/2015/06/coverstitch-machines . (Ending the double cover stitch hem is the same as that for the single cover stitch.)
I hope this helps.
Nov 27, 2017 | Vacuums
Vacuums Logo
201 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
