Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Problem with ice maker
I have double door Kenmore Elite Refrigerator and all of sudden it stop making ice and I can't figure it out. Thank you,
  • 706 Answers
With your limited input , all I can do is suggest some things for you to try..
First off, are you sure you have water coming to the back of the fridge? No water, no ice. Secondly, Can you gain access to the ice tray inside the ice maker to see if it is frozen with excess water ? If it is, you may need to thaw it out to free it up to allow it to cycle. If no ice buildup is found....
Can you tell if the icemaker is actually cycling? If you listen, you can here the inlet valve open to let water in and then you should hear the motor that rotates the mold tray operate ( may take between 10 - 20 minutes so be patient) If you don't hear any motor activity duing this time.... You may have a defectice ice maker assembly and may need to replace it. Hope that helps...
Posted on Aug 07, 2008
I need to defrost fan in the freezer. foe kenmore elite model # 795,72063,111 ice maker in fridge door
I have a Kenmore Side by side Refrigerator grab n go style door Model # 72063. The refrigerator is cold but the freezer is not freezing. Ice maker isn't making ice either. Could anyone tell me the part number for the compressor start relay? Thanks!
Aug 05, 2013 | Dryers
Kenmore Elite refrigerator, double doors, bottom freezer, not making ice error code comes up er1f Model # IS 79577563600
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 15, 2010 | Refrigerators
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
