Question about Ovens
I have a frigidaire pfef364cs2 range...I tried to use the self clean function and now the door lock light keeps flashing (the door is not locked) and an F9 message shows up and it beeps until you hit clear. the stove just keeps doing this...I've unplugged it and its the same thing as soon as I plug it in again. How can I clear this so I can use my oven?
  • 4 more comments
  • k_dubois03 Mar 22, 2011
    hi there...we have a "clear/off" button...tried your advice but no luck! I'm pretty sure the latch is broken...the previous owners of this home must have broken it...might just have to hire someone I guess
    this solution didnt work kevin...any other ideas?
    is there any way to just bypass the cleaning thing...I dont care if the function no longer works...I just need my oven to cook!
    i dont know if there is a way to "trick" the stove into thinking the latch is ok? just need to use my oven. I dont care if the self clean function doesnt work.
  • k_dubois03 Mar 23, 2011
    thats the thing...it never even heated up!
    hmmm...will try that and get back to you
  • 1,998 Answers
The f9 error code means the electronic control has found the lock motor switches to be out of sequence or shorted. you would have to perform a continuity test on the switches using a multimeter to assure that the switch is not burned out or that you do not need a new door lock assembly you would find these switches behind the rear panel of your oven. if the switches test that they are working properly you would replace the electronic control if you have any further questions message me back And please remember when our chat is fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Posted on Mar 22, 2011
  • 3 more comments
  • Rick Ead
    Rick Ead Mar 22, 2011
    also wait till the unit cools to see if this changes the door lock situation the f9 is most likely that you need a new door lock assembly if you need to get the door open go to the back panel unplug the machine and remove the rear panel you will see the door lock assembly usually if you spin the motor in one direction you can get the unit to unlock wait till the unit is cool to try this Thanks again for using fixya
    Rick
  • Rick Ead
    Rick Ead Mar 23, 2011
    it never heated up due to the door lock assembly not seating the lock into the full locked postion have you removed the rear panel of the machine? I have also seen others use a wire and pull the lock open i would not suggest this this sometimes causes more damage to the unit
  • Rick Ead
    by spining that motor to make the latch retract is the way you would trick the unit until you are able to buy the new door lock assembly
  • Rick Ead
    lol ok i will be here til tuesday then flying back home to New England I will await your reply Thanks Rick
  • Rick Ead
    be off from tuesday to thursday next week due to flying from hawaii back home
  • Ovens Master
  • 1,902 Answers
Hello & Welcome to FixYa
After reading your question the problem seems to be with the control which got locked. To unlock the controls press and hold the STOP/OVEN LOCK button for 20 seconds. If the problem returns then check the door and make sure it is fine, after this you can unplug the unit for 15 minutes and then try to reset it again. F9 error is a door lock circuit failure error code, after this if the problem remains then replacing the door lock-latch assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
  • Kevin White
    Kevin White Mar 22, 2011
    Alright...get back to me if you have any other questions
  • Kevin White
    F9 error can only be solved after replacing the the door latch assembly.
How do you keep the door locked so you can use t self cleaning feature
Good Morning Friend,
I understand you want to know how to keep the door locked on your Frigidaire oven, model# FEB24S2AS, so you can use the self-clean feature. The "Door Locked" light will flash until the door locks when the self-clean cycle is in use. It glows constantly after the door locks. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Lock light on frigdaire self cleaning oven
OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
Jun 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door will not lock to clean
hi, these two codes together are signaling a EOC failure. the electronic oven control has failed and you will need to replace the EOC/clock. it is unable to initiate any commands because, it in a frozen state.
You can try to reset this control by unplugging the entire unit for 5 minutes. if the control continues to not reaspond to your commands, replace the EOC.
please rate and god bless:)
Apr 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
