I've got a saunier duval thema F23E boiler that keeps losing pressure overnight ( It's switched off every night) I've downloaded the manual for this model and in my amateuristic way I've think I've worked out that the low water pressure switch probably needs replacing,would your experts agree and is it an easy job for an old age do it yourselfer like me to tackle
4 Suggested Answers
  • 15 Answers
SOURCE: I have a Saunier Duval
That code means low pressure.
The unit has either lost it's refrigerant charge or the coil is dirty. Look at the unit and find the metal fins. Make sure they aren't plugged up with lint and hair. There are two coils on an air conditioner, one inside and one outside. It won't hurt to check them both.
If cleaning the filter and coils doesn't fix the problem, it's time to have a technician come and check the refrigerant charge.
Posted on Sep 19, 2008
burty681
  • 56 Answers
SOURCE: low pressure for SAUNIER DUVAL
there is a blue tap at the bottom of the boiler when you turn it and nothing happends the screw had broken off inside you can do 2 things here put a new filling tap on the boiler , or get a filling loop put some where else on the system and if you still get low pressure replace the low water pressure switch...
Posted on Jan 31, 2011
SOURCE: we have a saunier duval
Hi, well usually it is unlikely that you indeed have an "Air Lock" as these are sealed systems, and would be further evidenced by the fact you would also most likely have been suffering "Water hammer" as well. which you didn't mention.
However all one needs to do, is drain the unit, from the Tap, and then reconnect the main water supply, and flush the system through. Now it is indeed possible that you may have blockage. It is possible hopefully, if it is not too bad the inrush of water may clear it? Often we use compressed air to clear out any obstructions if unable to clear by normal means this is unusual though.
Check you inlet valve, it maybe getting stuck, replacement is the only real option. Also check out that the protection mechanisms aren't faulty and stopping the unit from working correctly.
You really MUST obtain a service and repair manual if you do wish to DIY.
However in my professional opinion you will save money and time and headache if you simply engage a professional and ask for a "Quote' first, and proceed from there.
Below is a link to a place for a manual.
www.saunier-duval.co.uk/service/documentation_noncurrent.asp
Posted on May 11, 2011
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
Can I get a manual for a saunier duval instaneous gas water heater?
Yes. Just go through the company you purchased it from for this manual.
Sep 09, 2014 | Water Heaters
Saunier duval parts
If you are talking about the damper flap on the flue pipe. You have to go to a heating supply and buy a new flue that is already attached to a section of new pipe and fit it together. I'm not sure if your flue is free flap type of arm driven. British gas is trying to make a buck off you . Call a regular boiler repair man if you don't feel comfortable doing it your self.. Mine came apart at the hinge. The pin came out..I replaced it with a wire brad (nail) and it works just fine.
Dec 12, 2017 | Water Heaters
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
Low pressure Saunier Duval therma condens boiler
May need to replace valves (appear to be corroded and plugged with deposits) and install a water conditioner in the inlet line if you have hard water.
Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Feb 14, 2011 | Water Heaters
Low pressure for SAUNIER DUVAL TERMACLASSIC
Jan 31, 2011 | Heating & Cooling
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Dec 18, 2010 | Water Heaters
I have a 11 year old Saunier Duval and the hot water hardly works
suggest you call a repair service. gas appliances are dangerous to DIY they explode when people do not use the proper safety precautions
Aug 31, 2017 | Combi Centre DX - Mango
Heating & Cooling Logo
283 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
