Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Hi, I have a Tecumseh HMSK 80-110 snowblower with electric start. Everything was running fine until the last attempt to start it. I pushed the start button and it appeard to be dead. No clicks or any other noise. I verified that there was a good power source. Do I nedd to replace something? Herb
    President:
  • 2,468 Answers
Either the electrical start switch on the unit or the starter motor is bad,you can test the start switch with an ohmmeter,make sure the cord from the wall to the plug in on the units good too
Posted on Mar 22, 2011
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Yardworks snowblower problem engine no starting
check out the interlock switch system, check battery with a load meter first to make sure battery is up to snuff
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
My yardworks snowblower engine not running
need more information, several reasons why an engine won't run
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I need a manual
Try Home Depot. They carry a wide range of snowblowers with tecumseh engines.
Jan 09, 2012 | Tecumseh Snowblower Snow Blower Starter...
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I can't find my manual for a Tecumsah LawnBoy 824E 8.0HP Electric start snowblower. It starts fine, but does not continue running. I just filled the tank with new gas. It ran to run about 25 feet and then...
Hi
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Sam
Please vote
Jan 07, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
668 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
