Question about HP Office Equipment & Supplies
It says that my printer is off line how do I fix that?
    Scholar:
  • 103 Answers
Welcome to FixYa.
I also encountered same problem as yours, I do fix it by myself by doing steps below.
1. Turn off the Printer.
2. Unplugged the USB from computer
3. Restart computer.
Hope this information can help.
Thank you for using FixYa.
Posted on Mar 22, 2011
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
How do I fix an error that only comes up when I'm trying to fax a letter. The Error says: Phone Line Error. This is on a Lexmark X5340 all-in-one printer.
1) Make sure that the telephone line is plugged into the "LINE" port on the printer.
2) Test it with a different phone cable.
3) Is it a Telco line or an internet line?
Jul 01, 2011 | Lexmark X5470 All-In-One InkJet Printer
On my MP F80 printer, it says check printer ecm tx. What does it mean and how can I fix it?
Hello.
This refers to the TX (send signal) from your fax not working correctly. check the phone line or try the fax unit on another line.
If this does not fix the issue then a service technician will have to look at it as it is a problem internally with the printer.
Regards GM
Jun 30, 2011 | Canon PIXMA MP830 All-In-One InkJet...
The red light is on how to repair? (On line/ error)
the red light (online error) means that the printer is off line. How do you fix it? you press the "ok" or "reset" button and it puts it back on line and ready to print.
May 03, 2011 | Samsung ML 1610 Laser Printer
Hi, I have a black line that runs from top to bottom of the page when scanning, faxing and copying. How do I fix this issue?
the blcak line that runs from top to bottom is due to a dirty misaligned print head...do a full printer maintenance on your printer/scanner . Once the heads and rollers get clean and the printer is aligned, it should get rid of any black streaks or lines. I own a Brother Printer/scanner and it did the same thing to me, as soon as I ran maintenance on it..it fixed the black straks and lines I had on my prints.
Jun 18, 2010 | Brother MFC-9420CN All-In-One Laser...
My samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
May 31, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer "off line"
Check the cable that connects the printer with your computer, also check that printer drivers are installed correctly
Jan 29, 2010 | HP Office Equipment & Supplies
Printer doesn't print correctly.
My almost new F4100 printer is printing irradically, prints perfectly for two or three lines, then it fades to nothing, in a few more lines it prints perfect again. I can't find where to fix it.
Apr 09, 2008 | HP Office Equipment & Supplies
My printer makes lines through all the pictures i try to print
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
