Question about RCA 32F531T 32" TV
My 52" RCA P52937SG screen
  • 643 Answers
The part is called the convergence ic. replace those ics.
Posted on Mar 22, 2011
I have an RCA 52" projection screen tv, model #
This problem is a commom Convergence failure. The circuit is composed of two output IC's or chips. They will both need replaced at a cost of around $350 from most shops. If you're handy with a soldering iron you can give it a try but it is a critical circuit.
Bill W
integrityhomeworx.com
Mar 23, 2011 | RCA P52937 52" Rear Projection Television
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
Hi i have a RCA P52937SG with the bowing of the screen
The problem may still be on the power supply board (one of the supplies may be missing and) when you unplug the supply both supplies go missing check the supply voltages and repost
Oct 14, 2009 | RCA P52937 52" Rear Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32F531T 32" TV Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
