Where can I find a tv stand (to conect to my 18"
    Brigadier General:
  • 8,909 Answers
I would look in the local free press adverts. Or place an ad yourself.
Posted on Mar 22, 2011
I HAVE A LN-S4095D TV THAT WAS WALL MOUNTED NOW I WANT TO GET A STAND THAT WOULD SUPPORT THE TV ON A TABLE. I DISCARDED THE ORIGNAL STAND WHEN WE WALL MOOUNTED THE TV
Good luck with that. As soon as these sets go out of production, so do most of the parts associated with them. You would be better served to get a TV table stand that uses a wall-mount-style backer. That way you get the tabletop mount and the extra security of knowing it won't get knocked over easily. Something like this....
Aug 10, 2016 | Samsung LN-S4095D 40 in. LCD HDTV
Fixya TV
Contact the Sony authorized service center.
Apr 30, 2013 | Sony Bravia M-series Kdl-19m4000 19"...
I need a stand for my 26" PRIMA TV
Contact the authorized service center for Prima, or the authorized dealer.
Nov 29, 2012 | Prima Televison & Video
Prima tv takes long to turn on
Hello
If sound comes first, and picture comes after a long duration of time, the picture tube base connecting socket will have the fault. Replace it. This socket can be located on the abse card attached to the picture tube neck.
Mar 12, 2012 | Prima C2012 TV
How do you take off a stand from and lg 42inch lcd tv to allow to put on wall?
There should be screws of some sort on the back of the TV. they are the ones where the wall mount will attach to. remove those screws and as the tv is standing up you must pull up on the tv the stand has studs on it that run through the tv. if more assistance is needed can contact Phillip's Audio/Video at Phillzav1@live.com
Sep 05, 2010 | RCA L32WD22 32 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Legend televisions
get in touch with prima and ask them for a remote for the tv,don't forget to quote the model number.
Sep 22, 2008 | Televison & Video
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Mar 10, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
