Question about Cambridge Audio Azur 540R Receiver
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The speaker is ok and so is the cable. I've done a reset with no change. The maual indicates it might be a balance issue, but thier is no balance facility. Any Idea's
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Posted on Mar 22, 2011
Cambridge azur 540r receiver just stopped working. no power showing to on/off led.
Could have a problem in the power supply section. Check for open diodes and bad capacitors.
Sep 27, 2015 | Cambridge Audio Azur 540R Receiver
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
I have a Cambridge audio turntable which looses sound quality about halfway through record, as though it looses one of the channels (on the right hand side). I've tested the speakers, the amp, even had it...
Might be a weak relay or transistor in that channel, they both will stop and reset when overheated. make sure you're ready to test it when it does this again, this may help you locate the bad component. I'm leaning towards the transitor, because they also amplify sound signals in radio frequency.
Oct 06, 2010 | Cambridge Audio Azur 340A 2-Channel...
Protection overload and the system shuts off
Reasons: 1. Short in the wire, speaker, or amplifier 2. Amplifier malfunction 3. Overload of the amplifier 4. Overload of the speaker
Listening to audio at loud levels requires more power obviously. But the speakers and amplifier may not be rated or capable to handle it due to age or design.
Jan 13, 2010 | Cambridge Audio Azur 540R Receiver
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
check your speaker wires for short, try to turn it on without speakers connected, if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, fire hazard and electric shock are the things we all want to avoid ;)
Sep 02, 2009 | Cambridge Audio Azur 540R Receiver
When put in stero mode,the speakers blast out at full volume..
I had the same problem and have solved it bij resetting it.
Try the small hole above the powerswitch.
Good luck.
Oct 30, 2008 | Cambridge Audio Azur 540R Receiver
Cambridge Audio Azur 540R Receiver Logo
617 people viewed this question
Top Cambridge Audio Players & Recorders Experts
Don Hart
Tom Chichester
Steven Causey
Steven Causey
Level 1 Expert
Are you a Cambridge Audio Player and Recorder Expert? Answer questions, earn points and help others
