Question about Sony HVR-A1U Camcorder
Sony HVR - A 1 U touch screen does not work. I can not play the video from it
The menu icon wont function
This video goes over the problem you are having.
Aug 04, 2014 | Sony HVR-A1E HDV Digital Camcorder
D touch screen buttons on my Sony Hvr-a1p video camera does not work. I can't rewind, forward or even play video back.
Hello, try to reset the camera, if you need more help to repair your video camera i found a factory service manual for it you can download from the below link:
http://goo.gl/Ji4XI
Good Luck
Apr 19, 2013 | Video Cameras
View finder on my Sony HVR-Z5U isn't working, I can film through the flip out screen, but unable to use the eye piece view finder
POSSIBLY THE RIBBON CABLE THAT RUNS FROM THE EVF (VIEWFINDER) TO THE MAIN PROCESS BOARD SHOULD SWITCH REFERENCE TO EVF WHEN LCD PANEL MONITOR IS CLOSED REGARDS JOHN
www.jvsvisual.com
Mar 14, 2013 | Sony HVR-Z5U High Definition DV Camcorder
I have a sony hvr-z1j...and when I log filmed footage onto the computer there is a thick black border around the (16:9 or 4:3) visuals. There is no sign of the border on the lcd screen or viewfinder when...
Ha this sounds like you may have accidently pressed the AV button, it has special borders and setting within the camera, these are used for title effects and other tricks, just press the button again a couple of time filming and see if it vanishes.
May 20, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
HVR-a1u - Can I access the menu without using the touchscreen?
Don't have an answer, but two of our Sony HVR-A1U have now lost touch screen function. I wonder if this is a common problem?
Apr 24, 2010 | Sony HVR-A1U Camcorder
I recorded an interview on my Sony HDV camcorder, about 15 minutes in the screen goes blue but keeps playing. While in play mode, if I fast forward the interview pops back up but disappears as soon as I...
The heads are dirty and you are getting sufficient digital dropout to cause the blue screen. Try a cleaning tape. If that fails to correct hte problem, then the alignment needs to be checked by an authorized service center.
Dan
Sep 14, 2009 | Sony HVR-A1U Camcorder
I have a sony HVR A1U HDV and the LCD has stopped functioning. It's a touch screen LCD. I had it check by some trained technician who informed me that the problem was with the connecting strip/cable from...
I have experienced the same problem, which may well have the same cause. A local electronics shop told me parts for Sony are only available direct from Sony - so I guess you and I will have to contact a Sony dealer
Jun 17, 2009 | Sony HVR-A1U Camcorder
Sony HVR-A1U Camcorder Logo
64 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
