Question about LG WM-2077C Front Load Washer
I am getting a UE message. This happens the last 10 minutes of my laundry. The number stays at 10 and then it beeps with the UE light blinking and the laundry is soaked. This is very aggravating!!!
    Brigadier General:
  • 6,277 Answers
The reason it does not and cannot complete the cycle is that the washer is unbalanced so it 'knows' it cannot spin correctly, hence soaked laundry- that's what LG's 'UE' stands for Unbalance Error ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 22, 2011
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
Please can you help. My F&P smart drive 703 does not complete the water fill process. It stops and starts, filling with water intermittently and then suddenly beeps continuously as though it has
Maybe you have the cold tap hose connected to the hot inlet valve. Check the hoses. Need more info on the beeping. Is it a steady beep or more of a musical rippling sound? Also, what lights are on especially along top row when it beeps but also describe any other lights that are blinking? The top row lights won't be blinking, so just count and tell what number lights are on and which are off ( count from left to right)
Aug 15, 2017 | Fisher and Paykel GWL11 Top Load Washer
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung WF337AA Front Load Washer
What does "ue'"mean?
Jun 29, 2011 | Samsung Washing Machines
Error code "UE" clothes have
UE = Unbalance Error
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
Red message light is blinking on my Uniden phone and voice mail icon appears on screen when I have no messages. How do I get rid of the blinking light and the VM icon?
Our just started to do the same thing. Drove us crazy because there were no messages. I couldn't find the manual so I looked up the manual on their website. Here's how to fix it....IT WORKS! With the phone in "stand by", open the menu and select Global Setup.Select VMWI reset. Then select yes.
Sep 26, 2009 | Uniden 2.4 GHz Expandable Phone System...
Error message UE is displayed and the machine has stopped
UE means unbalanced load. This happens when the load is too small, or the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Jun 16, 2009 | LG WM-12230FB Front Load Washer
Letters UE on display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Dryer turns off in 10 minutes.
To check the moisture sensors. Make sure the dyer is plugged in and all controls are set to off. Next to get into the diagnostic mode press more time, less time, more time, less time, all within 5 seconds. Now all indecator lights on the console are lit up with 88 in the " time remaining" display, if the test mode has been entered. Now this how to check the moisture sensors. Open the dryer door. You may hear a beep sound and the software revision number will be displayed on the console. If this happens there is a short in the moisture sensor system and the moisture sensors need to be checked and probably replaced. If this doesn`t happen,locate the moisture sensors on the face of the lintscreen housing and lay a wet cloth or towell across them. You should hear a beep and the software number will be diplayed on the console. If this happens then the moisture sensors have past the test and your problem is even deaper into the electronics and may reqiure a technician to trace this problem down.I hope this has helped you.
Nov 10, 2008 | Whirlpool GEW9200L Electric Dryer
LG WM-2077C Front Load Washer Logo
119 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
