Question about Frigidaire Refrigerators
Frigidaire Model FRT04L5DB0, small dorn style. Plug in and starts to cool as it should. After about 1 hour, stops cooling & compressor gets very hot.
5 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Posted on Nov 30, 2006
Oceti
  • 51 Answers
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Posted on Jan 14, 2008
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 37 Answers
SOURCE: Compressor is getting very hot and no cooling
Sounds like your compressor is bad
Posted on Jan 03, 2009
My Daewoo freezer is not working since yesterday, we tried to change the fuse but it just works for 15 seconds then,it stops we don't know why can you help please?
I would think that the compressor is either overheating, or faulty and cutting out on a Thermal overload cut out device fitted to the compressor.
If it is overheating, then it could be due to several problems:
1] Ventilation to the compressor is poor, or blocked.
2] compressor Cooling fan failed ( not fitted on all models)
3] Condensor blocked ( Not fitted on all models) This looks like a small car radiator in the compessor compartment (if fitted?).
Turn the fridge off, and leave it for up to 2 hours to cool, once cool, ensure that the ventilation is good around the compressor compartment, and try it again. If it starts and runs as normal it may have just overheated. If there is a fan fitted in the compressor compartment, then observe if it is working or not when you turn it back on.
If the compressor cuts out again, as you have described, trhen it is more than likely that the compressor has failed and needs replacing.
This is not a job that a novice can do, and will be expensive to have replaced by a Refrigeration engineer.
I hope this helps?
Feb 22, 2016 | Daewoo Refrigerators
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
Maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Sep 30, 2012 | Maytag MFF2557HE Bottom Freezer French...
Has stopped freezing and cooling.
if compressor is working you will hear it. Take panel off and vacuum the area get all dust and debris of compressor and coils. This dust causes heat and will keep your frig from cooling. If that doesnt work try shutting down for about 6 hours like a defrost and restart.
Aug 16, 2012 | Frigidaire Refrigerators
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
Fridge just wont turn on any more. first it leaked water, then it got worse after that. THE FRIDGE SIDE STOPPED COOLING AND THEN THE FREEZER SIDE WENT OUT AS WELL. I CHECKED THE COILS AND DEFROSTED THEM...
try and replace the overload relay and start ptc on the compressor. if the compressor starts then you need to check the current draw on the compressor with a clamp meter if you have one.the current draw should be between 1.2 to 1.6 amps.if it is not within that range then replace the compressor
Aug 31, 2010 | Frigidaire FRS23W3A Side by Side...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
Refrigerators not cooling
no reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Sep 22, 2008 | Refrigerators
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Refrigerators Logo
    530 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
