Question about Cameras
Kodak easy share c663 camera high temperature
  • 643 Answers
Try new battery.
Posted on Mar 22, 2011
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
4 gb sd card not formatting
The C663 works with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to go with SD cards, 2GB and smaller.
Nov 25, 2010 | Kodak EasyShare C663 Digital Camera
Can C663 work with a 4 GB SD card?
No. The C663 uses SD cards 2GB and smaller, not SDHC cards 4GB and larger.
Aug 30, 2010 | Kodak EasyShare C663 Digital Camera
Can not email picture from easyshare camera
It is not possible to email directly from the camera.
If you're experiencing emailing difficulties directly from the Easy Share Software:
Please do a Clean Install on the software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 19, 2010 | Kodak EasyShare One Digital Camera
I have moister inside the lense of my kodak easy share dx6490. How do I open it so that I can dry the lense
Hello Steve, There is no easy way to open the camera,your best bet is to just let it set in a warm dry area for a couple of days.This usually occurs during times of high humidity or from a rapid change in camera temperature like warm indoors to cold outdoors.
Best Regards, Russell
Jun 12, 2009 | Kodak EasyShare DX6490 Digital Camera
Kodak c663 camera not working !
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Apr 24, 2009 | Kodak EasyShare C663 Digital Camera
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Lens won't go back in
some times if the batteries get wet it will short the system and it won't turn back on... if you dropped it something may have shifted inside blocking the messaging systems inside the camera. i would take it to a local camera shop.
Jul 08, 2008 | Kodak EasyShare C663 Digital Camera
Kodak Easy Share 663 Camera Help
Get onto the Kodak Tech Support site If it is in warranty they will fix/replace it If it is out of warranty there may be a reasonable swap out offer.
Jul 16, 2007 | Kodak EasyShare C663 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
