Question about HP LaserJet 4600dn Color Printer
How do i adjust the margins from the printer? HP color laserjet 4600 dn printer
  • 492 Answers
Usually in "page preferences" in the file drop-down bar. Then use "print preview" to see if the page looks OK.
Posted on Mar 22, 2011
How do you make an hp color laserjet 4600 dn recognize a quill remanufactured cartridge?
In 35 years of doing this for a full time living, I have never seen worse products thany toner or developer than Quill.
I would not buy that stuff if they were the last manufacturer in this solar system.,
Sep 12, 2011 | HP LaserJet 4600dn Color Printer
My network laserjet 4600 only comes out black not color both when printing and just a information page from the device
http://h10039.www1.hp.com/cpso-support-new/pq/4600/home.html
Try the above troubleshooting steps for each color page that prints out for test pages.
Try to click on 'magenta' for instance, and follow the leads to a solution for your black only print problem.
Feb 10, 2011 | HP LaserJet 4600 Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
Sep 09, 2009 | HP LaserJet 4600dn Color Printer
I have a HP 4600 series printers that are having
This problem may be an indication of needing the paperpick-up assembly repalced. It is hard to tell without seeing it.
Jul 07, 2009 | HP Color LaserJet 4600n Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
When I print my excel spread sheet on 11X17 paper portrait mode, it shifts the print about 2 inches to the left. Print preview shows fine. Printer HP color laserjet 5550 dn
It sounds like you need to do a page setup and adjust the margins. Hope that is the problem. Other wise I don't think you would get the shift. Bud
Dec 02, 2008 | Office Equipment & Supplies
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
HP PRINTER
isnt an 8500 dn a Xerox printer??
Sep 19, 2008 | Office Equipment & Supplies
HP LaserJet 4600dn Color Printer Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
