I have problem with my new laptop MSI CR420. The DVD/CD RW ROM drive can't read from CD, it's just can read from DVD. So can you help me to solve this problem....
  • sham110377 Jun 14, 2011
    I had gone through all the instruction as mention to solve my DVD/CD ROM drive problem,,,still can't work....so please advice me some other tip regarding the issues DVD ROM DRIVE can't read from CDROM
    Scholar:
  • 169 Answers
I am going to provide troubleshooting steps to try fixing this problem, since the disc drive can still read DVD disc its no longer a hardware issue, so im thingking this might be a software issue and the steps below might help you fixing this.
- click start > run and type "regedit" w/o qoutes
- once you access the REGISTRY EDITOR kindly open therse folder (each folder contains another folder) make sure to follow the below steps carefully.
- go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
- insed the "class" folder look for {4D36E965-E325-11CE-BFC1-08002BE10318} it is the CD/DVD rom drive.
- at the right part of the registry delete "upper" and "lower" filters name
- once done close the registry.
Go to device manager
- click start > run > type "devmgmt.msc"
- click the + sign beside CD/DVD drives
- right click and select properties
- go drivers tab
- and then select the button uninstall the driver
- RESTART THE COMPUTER
After restart all should be fine now.
Posted on Mar 22, 2011
Which drive on my satellite A 100 is the dvd or cd drive?
Your Drive : CD-RW/DVD-ROM COMBO DRIVE
This CD-RW/DVD-ROM drive is designed to read DVD-ROM discs as well as CD-ROM, CD-R, DVD-RAM discs
Oct 10, 2012 | Toshiba Satellite A100-S8111TD Notebook
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
My LG GCC-4522B CDRW/DVD ROM has got problem i cannot read any DVD but it can read VCD or cd-rw can u help my solve tis problem ?
This is due to a weak lens
Sometimes this type of problem occours due to excessive use of the drive in burning cd/dvd
Trying some leans cleaner may solve your problem
Feb 26, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
I am new too pcs my dell model c640 laptop will it play cds or dvds
Do the following:
1- Right Click my computer.
2- Select Manage.
3- Select Device Manager.
4- Select from the right pane , DVD/CD-ROM Drive.
5- See what comes under it , and read the letters.
CD-R = Only read CD
CD-RW = Read & Write CD
DVD-R = Read DVD & CD (mostly write CD also)
DVD-RW = Read and Write everything Except DVD-Dl
I hope this helps
May 10, 2010 | Dell Latitude C640 Notebook
LG dvd/cd-RW drive not reasd dvd bt read cd .help
i found when u burn too many cd,s on a dvd burner it stops burning dvd,s is this why ? buy a new one if its still new get ur money bk buy a different model : )
Apr 27, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Lg dvd rom is not reading the dvd and it is reading cd
sir,
my lg dvd rom is not reading the dvd and it is reading cd pls help me to find the solution to solve my problem. is any free software is avail.
thanking your
Jan 04, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
When I try to play DVD, nothing happens.
change the lens of DVD. its a common problem. due to over use.
May 31, 2009 | LG GCC 4520B CD-RW/DVD-ROM Burner
I want new laptop to write CDs - spec says DVD-ROM
http://reviews.cnet.com/laptops/lenovo-thinkpad-t41-2379/4507-3121_7-30567436.html
Thats the spec for yout laptop, if you have the plug-on module then you can write on it.
Optical Storage
  • Type CD-RW / DVD-ROM combo - Plug-in module
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 16x
  • CD / DVD rewrite speed 10x
Good luck
Nic
Apr 27, 2009 | IBM ThinkPad T41 Notebook
Need to fix my CD/DVD rom
hai
try to update the frmware of the dvd drive from the dvd drive vendor site.
Oct 10, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
129 people viewed this question
Alun Cox
David Payne
David Payne
