Question about Dayton Gas Furnace Heater
I have a Bryant 394B&D that lights up for a few seconds then the burners go out causing only cool air to flow thru the condo? How do I correct this problem?
    Genius:
  • Dayton Master
  • 1,033 Answers
Hello, check the flame sensor, this is a metal rod on the opposite side of the igniter. Turn off power to the furnace remove flame sensor and clean it up with some steel wool, then reinstall and turn power back on to the furnace.
Posted on Mar 22, 2011
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
Heater is not igniting
see this causes and fix it. God bless you
f there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below). If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
If the furnace makes a rumbling noise when the burners are off, clean the burner and adjust the burner air shutter.
If the air is too dry, wash or replace the evaporator pad if you have a humidifier; test the humidistat; and adjust the water-level float to raise the water level.
If some rooms are too cool and others too warm, the distribution system may require balancing. Refer to the Forced-Air Distribution Fix-It Guide .
Oct 08, 2012 | Intertherm Heating Cooling System 15kw...
Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
Apr 20, 2011 | Ruud Matching Split Air Conditioner
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
I have a Bryant Plus 90i furnace and a Bryant2.5 A/C
go mid.range....cfm dont go to hi spd or no cooling pick up
Aug 18, 2009 | Bryant Heating & Cooling
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
My A/C evaporator is freezing up, and wont cool the house below 85 degree
Check your filter and make sure you have one in place and it is clean. This is either a low inside airflow problem or system is low on freon. If you have strong air flow from vents and filter is been kept clean then low freon is most likely. Run system in on position with cooling off to make sure ice is melted. When water stops draining. then restart system . If it starts frosting up at outside unit shortly after start up it most likely is air flow. If you don't have at least 15 degree drop from registers in a few minutes and indoor humidity is not too high inside and airflow decreases and air gets colder just before it freezes up then it is low freon.
Jun 29, 2009 | Heating & Cooling
Bryant 36E93 gas package (pilot won't stay lit)
If your unit has a thermo-coupling this is most likely the issue This little sensor sends a milli-voltage to the gas valve telling it to keep sending gas for the pilot since its lit and all is good. They wear out and the gas valve thinks the flame has gone out (whick is hasnt) and kills the gas flow.
Jan 21, 2008 | Bryant 462AJC021BA Air Conditioner
Dayton Gas Furnace Heater Logo
122 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
