Question about Casio Watches
I have a GW-1701D-1AV solar powered watch. The watch is only about 6 months old and is constantly turning it self off and resting itself. I have turned the power saver off which does not make this stop. I recharge the watch in full sun every day and it still cuts out for short periods and rests itself. If i replace the battry will this fix the problem or is it another problem.
2 Suggested Answers
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
Removing metal wrist strap casio gw-3000bd
With most watches, use an Exacto knife to compress the pin to remove it. Replacing the pin is more difficult.
Nov 13, 2014 | Casio G-Shock Tough Solar GW-3000BD-1AJF...
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .
another prob might be low battery. put your watch in sun in order to give some power to your solar battery
Nov 11, 2013 | Casio Triple Sensor Pathfinder PRG60-1AV...
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
GW-1500A Casio has to be sunlight every day otherwise it stops
Hi gregbrands,
If your watch is several years old, I would recommend sending it back to Casio for service and battery replacement. Contrary to what you may hear about solar-powered watches, the rechargeable batteries do not always last for 10-20 years. I've seen some go out in 2-3 years. This is a shorter lifespan than most standard lithium watch batteries.
You may have an authorized Casio service center near you also. If not, contact Casio at the following numbers:
For Repair support in USA at 1-800-706-2534 during regular business hours (currently Monday-Friday 9:00a.m. - 5:00pm EST, Saturday / Sunday 10:00 a.m. - 8:00 p.m.) For Technical support in USA at 1-800-435-7732 during regular business hours (currently Monday-Friday 9:00 a.m. - 8:00pm EST for all products, Saturday / Sunday 10:00 a.m. - 8:00 p.m)
The cost of your watch well justifies this kind of service, plus, they will assure it remains waterproof up to its specifications.
Let me know if I can help further.
Thanks, Bill
Sep 15, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Need to replace casio atomic solar watch 2608 gw-300
May 14, 2009 | Casio Watches
Gshock gw 1500a light malfunction
yeas easy just hold the light button for a few seconds a beep will sound and it will turn off hold it again for afew seconds it will go back to turning on by it self
Jan 05, 2009 | Casio GW1500A-1AV G-Shock Atomic watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Dec 31, 2006 | Casio G-Shock GW1200BA-1AV Wrist Watch
Watches Logo
74 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
