Question about Conspiracy The Shadow Raptor Cassette BMX Bike Hub 36H RHD 9T Black
My cassette has a good sound and a day and began to uncover disturbing and oil and now has almost no sound, I do to restore the sound?
  • 76 Answers
Take your driver out of the hub and clean the inside of your hub with carb spray (or something similar) this will make your hub as loud as possible unless you buy new springs
Posted on May 20, 2011
Just had my oil and filter changed and almost immediately noticed a knocking sound. Two days later my check engine light began to flash and the knocking got louder
Have you called shop that did oil change? Have a different shop check oil and filter to make sure proper filter used especially.
Feb 04, 2014 | 2002 Chrysler PT Cruiser
Sound Issues with Stereo System
It is more than likely the audio output transistors have shorted out, test equipment will be needed to find out the extent of damage.
Sep 02, 2012 | Audio Players & Recorders
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
Feb 05, 2012 | Pioneer Audio Players & Recorders
2001 ford ranger 4.0 engine timing chain replacement
Hi Josiah:
According with the repair guide...4.0L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Engine from the vehicle Oil pan Engine front cover Cylinder heads
  4. Lock the jackshaft tensioner by installing a pin.
    Jackshaft sprocket and chain assembly Left front cassette retaining bolt Cassette chain and tensioner assembly Rear jackshaft plug from the engine Right rear cassette retaining bolt and spacer Right rear cassette chain and tensioner Timing chain (s)
Fig. Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
Zooming link for Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
To install:
  1. Install or connect the following:
    Timing chain(s) Right rear cassette chain, tensioner and sprocket Jackshaft sprocket and chain on the engine and remove the tensioner pin
  2. Torque the jackshaft sprocket bolt in 2 stages:
    1. 32-35 ft. lbs. (43-47 Nm).
    2. Turn an additional 65 degrees.
  3. Install or connect the following:
    Cylinder heads Front cover Oil pan Engine to the vehicle Negative battery cable
  4. Fill the engine with clean oil.
  5. Start the vehicle, check for leaks and repair if necessary.
  2. With the vehicle in neutral, position it on a hoist.
  3. Remove the intake manifold.
  4. Remove the fuel supply manifold.
  5. Remove the accessory drive belt.
  6. Remove the thermostat housing.
  7. Remove the roller followers.
    NOTE You must retime the LH and RH camshafts when either camshaft is disturbed. Turn the crankshaft clockwise to position the number one cylinder at top dead center (TDC).
    NOTE The special tool must be installed on the damper and should contact the engine block to position the engine at TDC.
  8. Install the special tool.
    NOTE The right-hand camshaft sprocket bolt is a left-hand threaded bolt.
    NOTE If necessary, use camshaft gear torque adapter to loosen the camshaft sprocket bolt.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 08, 2011 | 2001 Ford Ranger Regular Cab
Began a slow ride on a 55 degree day , was warming it up gently and it began to miss like it was running out of gas and SEVERE oil smoke began coming from exhaust.
sounds like maybe broke a ring or it's stuck. Old school fix for stuck rings is to fill cylinders with Marvels Mystery Oil, leave alone for a couple days, drain and try it.
Dec 27, 2010 | 2001 Suzuki GSF 1200 Bandit S
My Sony DCR-PC0-109 had been working just fine. Then one day I was checking to see the available space on my tape, and the camera would not insert the cassette. I tried another cassette, thinking that was...
It seems that your cassette holding alignment has been disturb... Since Sony does not provide service manual, at home we can try our luck only....
Check out this, while inserting cassette analyse that which side of cassette is stucking and try to figure out causes for the same, that means check whether there is any displacement has taken place....
Jun 22, 2010 | Sony Handycam DCR-PC109 Mini DV Digital...
Oil light comes on after about 10 minutes of running. usually turns on everytime i stop
I would take a look for the oil sending unit and check that the wire going to it is secure, as this sounds to be electrical. Good luck and remember to rate all the solutions you get, thanx.
Oct 30, 2008 | 2004 Dodge Neon
Back Massager tips
Avoid rough or sudden movements as you cover and uncover the different areas of the body.Make sure you place the towel gently and avoid abrupt movements that might be disturbing to someone in a relaxed state.
Aug 27, 2008 | Homedics 10 Motor Back Massager with Heat
MOISTURE?
For Moisture problem, dryer is an option and can be used. For head cleaning purpose, use any good quality or Sony Video Head Cleaning Cassette V-8
Aug 15, 2008 | Sony CCD-TRV338 Hi-8 Analog Camcorder
Conspiracy The Shadow  Raptor Cassette BMX Bike Hub  36H RHD 9T  Black Logo
Top Conspiracy Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Conspiracy Cycling Expert? Answer questions, earn points and help others
