Question about Simer 1/2 Hp Thermoplastic Submersible Sump Pump
When pluged in at first it just hummed I then took off the bottom screen and turned the impeller and about a 1/4 cup of oil came out I then pluged it in again and it ran. should the oil that ran out be replaced if so how
  • 56 Answers
The 1/2hp model holds around half a quart of oil so it may have just been over filled. What is worrying is that it leaked at all. Any small leaks can be patched with superglue gel if allowed to harden overnight. Make sure your patch will not interfere with the impeller and it should hold for years to come. If you can not locate a leak and no further oil is coming out monitor the unit for over heating for about 4 hours of running time.
Posted on Mar 22, 2011
How to clean the food trap
Usually hex head screws on impeller and the spray arm should have a hand screw in center. Loosen hand screw and spray arm comes off then remove screws on impeller and lift it up. Once off I like to clean it with 1/2 cup baking soda dumped into opening then add some vinegar. Reaction will bubble and it loosens any gunk that's there. Reassemble and run dishwasher on quick wash with two cups vinegar added to bottom of dishwasher
May 03, 2015 | Dishwashers
My R520-T7 pump hums but will not turn on
sounds like a jammed or detached impeller, located at the bottom of the pump motor. Repairs are unreliable and replacement is inexpensive ($130 for a comparable pump) recommend replacing the pump.
May 10, 2014 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Plug on bottom of motor on my 01 dana i drained about a cupful of oil out of then took the 5/8 plug out and drained rest of oil, what is the allen plug for?
Hi Pawpaw32, That plug drains residual oil out of the cam compartment for inquiring minds that want confirmation that metal ants and shrapnell may or may not have taken up residence. Good luck
Apr 17, 2013 | 2003 Harley Davidson FXDL Dyna Low Rider
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
I bought my rule pump 1800 hp 1 yr 3 months ago now wont work what should i do
check that the impeller on the bottom is't frose or debre pluging the pump push a stick in the out nozzle to turn the impeller try again see if it works
Feb 27, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
Pump quit....gets hot!
THAT IS A CHEAP PUMP. JUST BUY A NEW ONE, THEY ARE HARD TO GET SEALED BACK UP AND JUST TO FIND IT WORKED FOR A WEEK.. VEGETABLE OIL .. IT MUST BE NON TOXIC OIL !! .. VOTE
May 24, 2010 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
My sump pump hums, but the propeller doesn't turn.
yes the pipe is the same size all the way through, if it is just humming and there is nothing blocking it, the motor could be going bad and doesn't have the power to turn the pump,, did you check to see if the shaft could be bent> like as if a rock may have gotten stuck but broke loose before you took it apart
Jul 08, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Samsung Washer WF306LAW stopped draining and won;t spin
Drained the water from the tub into a bucket. Since the water flowed through the disharge tub I knew there were no obstructions in the line. I then took took the discharge pump out and took it apart. Turned out to be a bobby pin in the motor that was jamming the impeller.
Put it all back together and it works just fine. Took me about 2 1/2 hours total to diagnose and repair.
Aug 30, 2008 | Washing Machines
Simer 1/2 Hp Thermoplastic Submersible Sump Pump Logo
128 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Simer Garden Expert? Answer questions, earn points and help others
