Question about Canon imageRUNNER 600 Printer
I am getting e020 error switch main off and on again and again
E020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Posted on Apr 12, 2011
E020 00a3
needs fuser assembly. probably bad thermistor.
Nov 14, 2012 | Canon CLC 1140 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
We were copying and the error code E020 04E0 came up
Error code E020 04E0...there's an error in the developer unit...check the developer unit and see if it's working properly...
Jun 23, 2009 | Canon CLC 1150 Color Copier
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 600 Printer Logo
296 people viewed this question
old marine
old marine
