Question about Kenmore 54501 Dehumidifier
It was working fine, I shut it off and the next time i turned it on nothing happened. None of the front lights lite up. like a fuse was gone or no power. I checked all the obvious including the small fuse inside the unit,all ok. help
  • Kenmore Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
Why does nothing happen when it is plugged in and switch turned on?
Your dehumidifier may be set for automatic operation when a certain level of humidity is detected.
May 26, 2015 | Comfort-Aire BHD-301 Dehumidifier
Tip
Meaco dd8l fault light.
Not long after my unit ran out of warranty it developed a fault. Less then a minute of being turned on the double fan light would begin to flash and the unit would shut down. The filters were regularly maintained as recommended my the manufacturer. I am not one for just throwing it out and buying a new one, so I stripped it down.
i noticed the dissident wheel was not turning so I removed the motor, stripped it down and re greased the plastic gears within. Then I noticed the dissident wheel itself was catching on something (motor still removed) when I manually turned it. After taking the dissident wheel off I could clearly see the plastic housing behind the wheel was melted and snagging the metal 'spokes' on the dissident wheel. The area is located directly behind the heater unit.
after flattening the plastic down smooth, the unit is now working.
I have concluded the reason this may have happened is the unit being switched off before its shut down process had finished, meaning the metal 'spoke' was stopped next to the plastic with the heater still hot enough to heat the spoke enough to melt the plastic behind causing a snag for the wheel.
so I think the shut down procedure is quite important before turning it off at the wall.
on Jan 01, 2017 | Dehumidifiers
FDK45P11
Hi! Same thing just happened to me. There's a black plug in the back that just pulls off. It's no bigger than a dime. Once I pulled that off some water came out, not that much but enough to get my machine working. Hope that helps!
May 11, 2012 | Frigidaire FDL45P1 Dehumidifier
Unit does not turn on when the on-off button is pressed. No indicator lights come on. The line cord is good - I have 118 volts across the black and white wires inside the cabinet.
This unit has a 12 amp 125v glass tube fuse on the control board. Chances are you blew this fuse. This can happen if the unit is starved for air and ices up. you must take the front of this unit off to access the fuse of this control board.
Apr 08, 2010 | Haier HDN655E Dehumidifier
I have a LG LHD45 EL dehumifier, stopped working suddenly
Check the glass fuse on the circuit board inside the power supply at back of unit (have to take off cabinet)
Dec 03, 2009 | LG LHD45EL Dehumidifier
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Control panel lights up-nothing else happens
first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Dec 16, 2007 | Kenmore 5365 Dehumidifier
Kenmore 54501 Dehumidifier Logo
119 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
