Question about LG Refrigerators
LG REFRIG ERROR CODE ERIF - LG Refrigerators
What does CF E mean on my LG refrigerator?
With LG 'smart' refrigerators, the error code CF means that the refrig control board 'thinks' the condenser fan down by the condenser coil is not working. I don't know ow the board senses that, unless it's a temperature sensor on the condenser coil signaling the coil is running too hot. It could be dust blocking the coil air flow, a bad fan (locked up or running slow), a bad sensor, a bad control board, you name it!
May 12, 2015 | LG LSC26905TT Side by Side Refrigerator
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I...
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Mar 21, 2011 | LG LFX23961ST Stainless Steel Bottom...
ERIF code no ice or water dispencing Is this an internal fan fault ? whats the fix?
Replace the evaporator fan motor.
Part#4681JB1017D
You may also need the main computer. Usually it is the fan motor.
Jan 08, 2010 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a LRFC 22750 SW   LG bottom freezer with french doors.   I have been getting an error message on the digital read out ER on the refrigerator side and I think DH on the freezer side.   I  unplug...
You will get this error code if a sensor does not reach a certain temperature (+8 C, to be precise)within 2 hours of going into a defrost cycle. Increased frequency probably means the defrost build up is causing your refrigerator to run more, which will bring on the defrost cycle sooner, and the error code to repeat sooner. So, it really looks like your refrigerator is not defrosting. Soon, you will have inadequate cooling. A temporary fix to the poor cooling problem would be to unplug the refrig and open the freezer for a day or so to let it defrost on it's own, but the frost will then begin to build up again, resulting in poor cooling, depending on climate and door openings, possible in less than two weeks. Better look for service soon. If you are in the US, you can try http://us.lgservice.com/index_b2c.jsp to find service using your zip code, or call LG at 800-243-0000.
Feb 01, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
265 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
