Question about Dyson DC11 Allergy Bagless Canister Cyclonic Vacuum
I have got a dc11 allergy hoover. All the pipes are clear, cylinders are clear, filters are clean,brushes clean, cant find a blockage anywhere. But it still isnt picking up bits from the carpet very well . Please help
5 Suggested Answers
  • 98 Answers
SOURCE: dc11 dyson
I have taken the brush heads off and pulled all the hair out of the small gap between the chrome shaft and the plastic gear housing. Then a small amount of 3-in-1 oil into that gap to lube the internals and just a little through the air intake on the side of the head to clean and lube the seals and it works like new. This lasts about 9 months under high use and the process takes roughly 10 minutes.
Posted on Mar 23, 2009
SOURCE: Dyson DC08
i managed to take the cyclone apart. here is some help with what i did I hope this helps. You will need a philips and torx screw drivers. Especially torx with T - handles and thin shaft makes the task much faster and easier.
1. first undo the screws holding the top handle.
2. lift that part of the handle and pull towards the other end of the handle at the same time. Care this is a tricky manoeuvre but the other end is just sloted in. sometimes may be glued so some force may be needed. see photo 1
3 Once the handle is off. there will be screw under the end that you pulled off. undo that screw. see photo 57bd18a.jpg
4. Now turn the cyclone upside down. Pull the cone off. this is only a push fit and should pull off
5. Now you should be able to see the three torx screws holes as indicated in the photo.38c6322.jpg
6 The removal of these torx will enable this section to be pulled off exposing one more layer with three further torx screws to be removed as indicated in the next photo7a60cdc.jpg
7 Once the final torx screws are removed, turn the cyclone upright and the top bit which held the handle should come off exposing the complex combe structure. see photo 92fa764.jpg
8 Then you should be able to lift the combe structure as well see photo 349cdfc.jpg
10. Thoroughly was all the parts with water and make ABSOLUTLY sure that the part are dry before putting it altogather again. Your vacuum will be as good as new. mine was. good luck and happy cleaning.
Posted on Apr 11, 2009
  • 389 Answers
SOURCE: Dyson DC 24 blockage between brush bar and
You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Posted on Jan 06, 2010
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
DysonInfo
  • 107 Answers
SOURCE: Dyson DC 14 Animal - The carpet brush does not
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Posted on Jan 21, 2011
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Root cyclone 12 loss of suction. How do I solve as both filters have been cleaned
Hi Pat, it's Jack at Dyson.
Performance issues are usually simple to resolve. DC11 has two filters - the 2-part pre-filter (the yellow plastic outer casing the the blue foam inner section) should be washed at least once every three months. The post-filter is engineered to last the lifetime of the machine without maintenance or replacement. If you have washed the post-filter, unfortunately this may have caused damage and we would recommend replacing it.
It sounds as if your machine has a blockage somewhere in the floor tool, wand or hose. To locate and remove this please follow the steps shown in our online support guide: http://www.dyson.com/support/dc11/dc11-sy-allergy/using-my-dyson-list/redirect-to-dc11filterwashvid/dc11filterwashvid/flo-dc11-gen-blockage-procedure6
If you'd like some further advice from our experts after you've given this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 01, 2013 | Dyson DC11 All Floors Bagless Canister...
Not picking anything up
I'm sorry to hear you're having difficulties with your DC11. From your description of the issue, it sounds as if you may have a blockage in the turbinehead. To check for and remove any blockages, please follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc11/dc11-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-turbine-head/turbine-head-maintenance
This should resolve the issue, but if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Feb 09, 2012 | Dyson DC11 All Floors Bagless Canister...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Dyson power head stops when on carpets, cleaned brush out, still happens.
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Jan 31, 2010 | Dyson DC11 All Floors Bagless Canister...
How do I replace the motor brushes in my DC11? I cannot dismantle beyond removing the pipe attachment. I've removed the 6 fixing screws that are visible, but the machine is still firmly "together" as if...
I've never worked on a DC11 but have worked on several types of Dyson uprights. The following may or may not be relevant to the DC11 but may give you a few clues.
On the uprights I've worked on, if you remove the dust canister, underneath it is a clip-on cover with what's known as a post motor filter under it. This varies between models from a simple fibre pad, to a plastic encased paper filter very similar to the one that goes in the top of the dust canister. Having removed the clip-on cover / pad / filter, there should be a few more screws that when released will allow the motor housing to be taken apart.
The site www.dysonmedic.com is excellent, but doesn't yet cover the DC11.
Incidentally, I've just repaired my fathers DC07 which appeared at first to be a brushes problem. When I got it apart, it became obvious that the motor armature had a worsening fault whereby it was overheating so badly the over-current trip on the motor kept cutting out. The overheating was so bad that the bottom of the post motor filter was actually burnt !
Searching on eBay, I found a complete replacement motor for £18 inc p&p, but no listing for brushes. You may therefore find a) it isnt the brushes and b) you cant buy the brushes separately anyway.
Good luck !
Sep 02, 2009 | Dyson Vacuums
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Dyson dc11 makes a groaning sound and no suction
It is more than likely that you've caused blockage in your turbines. Plaster dust is very very fine and will have passed through your filter quite easily. It's also more than likely that the plaster dust has affected your motor.
If you turn it on and you hear popping, then motor is more than likely deceased. If you hear something like a valve releasing when you turn the machine off then there may be a blockage.
Probably best to refer to your local Dyson via www.dyson.com
Apr 01, 2009 | Dyson DC11 Allergy Bagless Canister...
Dc11 dyson
Mar 30, 2008 | Dyson DC11 All Floors Bagless Canister...
Dyson DC11 Allergy Bagless Canister Cyclonic Vacuum Logo
88 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
