Question about Samsung SCH-u540 Cellular Phone
Loose lcd I got my new phone less than a month ago and I noticed when the phone is closed the LCD piece wobbles back and forth just a little. Is there supposed to be some 'play'? I didn't notice it at first. It doesn't wobble when the phone is open. I noticed my old Samsung started doing that right before it broke and I'd had it 2 1/2 years. Thanks! I'm technologically challenged! It is a Samsung SCH-u550, not a 540
Do you mean the whole part that flips up? if so my phone is the same way, it is a 540 though, hasnt caused a problem yet.
Posted on Sep 02, 2008
1998 voyager front tires wobble back and forth when jacked up. Is it tie rod or ball bearing?
If it wobbles with your hands at 9 and 3, its a tie rod end.
If it wobbles with your hands at 12 and 6, its a wheel bearing.
Feb 19, 2015 | 1998 Plymouth Voyager
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Aug 30, 2017 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
Fan & shrould Broke off the water pump
I believe that the part your'e talking about is the clutch for the fan. It is a two piece unit, factory assembled. likely the bearing inside failed and caused this. You can change the fan and clutch unit, inspect everything for damage from the fan becoming disconnected and be OK, however running and wobbling may have caused some bearing damage in the pump...keep an eye on it...any noises or leaks from there, change it.
Mar 24, 2009 | 1995 Nissan Pathfinder
A105-S1014 LCD Screen issue
the LCD inverter maybe going bad and i would check for a lose wire or the lcd cable may have a brake and when you pull or tap it moves
Dec 20, 2008 | Toshiba Satellite A105 Notebook
Bubble-like spots on lcd
Your Licquid Crystal Display appears to have gone bad... much like a dead pixel in a TV, you get a dead spot on the display of your lcd that looks like a bubbe.
You need to have the screen replaced or you will have to live with the bubbles. If the PC is still under warranty I'd send it in for repair. You may be able to pick up an inexpensive replacement on eBay, but make sure you are careful if you replace the screen yourself.
Apr 27, 2008 | Acer TravelMate 4150LCi Notebook
Screen loose
Open your laptop case(Not LCD case) & see the mechanical portion is damaged. IF possible change this parts by byeing secondhand parts from scrap area/ put some synthetic(Do not use petrolium gum) gum & plastic & finish it properly. I think IF you can make it properly it could solve your problem.
Feb 05, 2008 | IBM ThinkPad X41 Tablet PC
Nothing on screen
ltd1991 - take the phone to either a mobile tech or mobile service center close to you and have them replaced either you flexcable or LCD screen.
mk_rodgers74 - you need to have the ear-piece replaced but you will also have to get the lcd change at the same time seeing that the lcd and ear-piece are both connected to the board or they meaning the mobile tech or mobile service center could unsolder the old ear-piece and resolder the new one back to the lcd board.
Dec 04, 2007 | Samsung SGH-d807 Cellular Phone
No dispaly on screen.
Three possibilities. 1) The LCD screen is cracked from a fall or hit etc.. It can be visible or a small crack hidden on and edge or corner, only visible after taking out the display. 2) The phone was exposed to moisture or high humidity long enough for corrosion to start. This could have happened many months ago. The corrosion has finally effected the LCD. If you're up to disassembling the phone you can clean the LCD connector with rubbing alcohol and a tooth brush as well as clean the LCD cable itself with a pencil eraser. Typically the LCD is held in with a little 2-color connector that you open with a tiny screwdriver or other tool by carefully prying off each side of the connector a little bit. (1-2mm) when you are done just slide the lcd connector in all the way and push the connector back in. 3) It's unlikely but the LCD can just stop working. It's not worth paying $30 to $50 for a new one. Just replace the phone.
Jul 12, 2007 | Panasonic KX-TG5622M Twin Cordless Phone
Fell too many times
HI Mary As you know that most small cell phone case was made by plastic. Therefore, if you has droppd so many time, the impact causes most damage to the hinges and connector and if you love your phone then you can purchase the OEM housing on Ebay and have someone to replace it. The OEM LCD ribbon is always paired with the main LCD so if you purchase this cable, you should have the LCD as well. However, since you dropped the phone too much, it is not worth to fix if you don't know how. I can fix the phone and can replace anything in it but I still prefer to get the new one since even I know how to fix, parts and time to spend is already cost more than the new phone ususally cheap today if you need to use as a communication tool not entertainment tool or work one like PDA, Smartphone. Phone has too many time dropping will not work well one day and can die anytime. so buy a new one and keep this as replacement part. good Luck. Regards, Jospeh
Dec 02, 2006 | Samsung SPH-a660/VI660
Samsung SCH-u540 Cellular Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
