Question about Garden
What engine was fitted to mountfield M1 serial no M1/11132
3 Suggested Answers
  • 168 Answers
SOURCE: no spark on GV100 honda engine mountfield laser
I assume you replace the coil due to the fact you didn't have any spark. If so, make sure you have the leg gap to flywheel correct. 12 thou should get you spark. However, if still no spark, check out the switch at the lower section of the cable. May only need an adjustment there, as the old cable do stretch with time and the gap is now incorrect. Make sure when you engage the cable that the switch isn't still grounded. Also, check the flywheel key to make sure it's not sheared off. Good luck
Posted on Oct 09, 2009
  • 429 Answers
SOURCE: Will a honda engine gx 340 11 hp engine fit
i would say no,especially due to the fact that the gx340 honda is a horizontal shaft not a vertical shaft which many lawn mowers utilize better chance with a gxv 340 honda.
Posted on Jan 08, 2015
What year was my m1 made the serial number is 22000002
For starters, you DIDN'T state if it's a M1 Garand, or a M1 Carbine.
But, it doesn't matter.
Neither one had a serial number range into the 22 MILLIONs that you stated!
Did you type one digit too many?
Sep 30, 2014 | Optics
Repair manual mountfield cultivater m1
Does this cable have a small lead end ? Turn it vertical and slide it
into a spiral shape on carburetor the cable should pass through a groove facing the operators handle. Don't cut the lead end in anyway it won't work for you if you do.
Apr 22, 2014 | Mtd Garden
Broken clutch on Mountfield Empress 84104
I'm sorry but I believe you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jul 05, 2012 | Cars & Trucks
Primer bulb slpit
They have um for other machines on eBay...some may fit your machine and may carry some at your local small engine/lawn mower repair shop. Compare your type to the ones you find.
Jun 03, 2010 | Garden
no it will not fit unless some modifications are made
Sep 13, 2009 | Garden
How much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
How do adjust the mixture on a mountfield 470
Depends on what engine is fitted - but the chances are no adjustment is possible. The mixture is fixed, and the engine has a governed idle - which means there IS no 'idle speed' in the conventional sense.
If mixture adjustment seems to be required, the carb needs cleaning.
Aug 24, 2009 | Garden
I need onwers manual for Mountfield Laser Delta mower
Have you Contacted Mountfield about a Manual? You can Contact them Using the Options at this Site Addy;
http://www.mountfield-online.co.uk/contact?jssCart=13a24ca4de2a2610f7213de8a0539ffb .
For an Engine Manual you can Contact www.outdoordistributors @ 877-707-2787 or Contact Tecumseh @ 800-558-5402.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
