Question about Samsung ML-1630W Monochrome Laser , up to 16ppm/A4, 17ppm/Letter, Resolution 1200x600dpi, USB... Printer
We have a samsung ML1630W printer, and would like to turn off the wireless. Is this possible?
My Samsung ML1630W printer has stopped working. It is listed in the printer folder, but when I print it comes up with an error message.
The best thing is, turn off the printer, unplug it, wait one minute, re-plug it in and press the on button. It will take a few minutes to reboot and if this does not correct the problem, delete the printer and it programs from you computer and reinstall the drivers.
Hope this helps.
Sep 21, 2014 | Office Equipment & Supplies
Can you connect tablet to printer
Check on play store by entering the make in the play store search eg. If you have an person printers, search for person. If there is a wireless app for your printers it can be downloaded here
Sep 12, 2014 | Tablets & eReaders
Samsung will not turn
Dear
The problem is at SMPS, you need technicians help.
Thanks.
Jul 30, 2014 | Samsung CLP365W Wireless Colour Laser...
Hey ! I've got a DELL Wireless 2350 Broadband Router and it's working just fine. Recently I purchased a wireless printer (Samsung ML-1856W). I get the printer to work via the network if I...
My first thought would be to try different forms of encryption on your router. It's possible that your printer may not support the type of encryption you're trying to use which may be causing it to have trouble connecting. For example, if you're using WPA encryption, try switching to a WEP key instead. You can change all of these settings from your Wireless Router's configuration page.
Jul 24, 2011 | Dell Wireless 2350 Router
How to I connect using the wireless feature I have purchased a new computer but cannot get it to connect wirelessly to my samsung 315W. The new computer is running windows 7
According to the Windows 7 compatibility list, your printer should work. Check here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Hardware&s=Samsung%20CLP-315W%20
I am not familiar with this particular printer ... it is wireless? Can you attach it to your network wired? My preference is always wire if possible. Faster and more secure.
I suggest you remove the printer from the computer and reinstall it.
Thanks for your quesiton @ FixYa.com
Mar 24, 2011 | Samsung CLP-315W Laser Color Printer
Converting Samsung ML-2510 laser printer to wireless
Hi there
I done my printer wireless I bought a wireless adapter that gos on the printer and works from my router.
I bought it off Ebay it was only £10 if you going to get one look in ebay but dont buy the first one you see as I said you can buy one cheap off hongkong
Feb 20, 2010 | Samsung ML-2510 Laser Printer
Question: Samsung CLP-600N, Vista
Possibly two problems here.
1) Printer on before PC to get a print - an IP address problem ??
Is the IP adress of the printer a STATIC address (usually works better and more reliably), or is obtaining its address from a DHCP server (typically a router, wireless router etc)
Doing an Information print (MENU, ENTER, ENTER) should tell you how the printer is set.
2) Unable to get multple copies.
Possibly a driver problem - get the first sorted out then see if it still does it.
Jan 08, 2008 | Samsung CLP-600N Laser Printer
Samsung scx4100
Check for any paused or failed print jobs. 1)Cancel or delete them. 2)Reboot computer. 3)Shutdown the printer for a few minutes. 4)Turn-off printer and computer, wait 5 minutes, turn on printer|turn on computer. Let me know more information if you can. Thanks Tim
Mar 13, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung ML-1630W Monochrome Laser , up to 16ppm/A4, 17ppm/Letter, Resolution 1200x600dpi, USB... Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
