Question about Whirlpool Duet GHW9150P Front Load Washer
The drum on my duet washer separated from the boot gasket. The primary cause was overloading the machine with heavy rugs that should have been taken to a commercial laundry. Should a person who is reasonably competent mechanically be able to change the gasket? Could the weight of rugs have caused additional damage such as a bent axel on the drum or stripped bearings?
  • Whirlpool Master
  • 8,220 Answers
Posted on Mar 22, 2011
Drum flopping around and making clunking noise
Almost certainty that the bearings are faulty, major problem usually no worth repair fault is caused by overloading the machine
Nov 23, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
My duet washer is leaking beacuse the seal is not aligned right, the metal ring that holds the seal in keeps popping ou..any advice?
Carefully pull the nozzle from the window washer tube. Separate the plastic gasket ring from the nozzle. Insert the nozzle through the hole in the boot and slide the plastic gasket ring down the shaft of the nozzle so that the boot is securely trapped between the gasket ring and the nozzle ridge. Insert the nozzle shaft into the window washer inlet tube and insert the end of the water inlet tube into the boot. Fit the boot around the front lip of the tub so it rests smoothly and evenly. Fit the boot clamp around the front lip of the tub and tighten the screw. Be careful not to over tighten this screw. Damage to the boot clamp or the boot could occur.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello. It looks like the rim of the tub is
sounds like the rubber boot from door to drum is worn.  can be replaced but suggest a pro do it..
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need bolts to stabilize washer for move
Dont know if you can purchase these. First people to try are the manufactures. Otherwise, unscrew the two screws at the rear top of machine and pull backwards to remove top.Then pack some towells or rugs around the drum then replace top. Don,t forget to remove rugs at new home.!! Good luck on your move.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose"
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
205 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
