Question about Acer 3002LCi ZL5 Sempron 64bit 2800+ (AC3002LCI) PC Notebook
First the lapton screen asks to start in normal mode or safe mode etc. i hit normal mode and safe mode but still the smae problem. The laptop startup windows xp but shuts down direct after
    Brigadier General:
  • 8,909 Answers
As soon as you can get it to run either in safe or normal mode, run CHKDSK/F as that will attempt to repair the hard drive errors.
Posted on Mar 22, 2011
I have Vista for Business on a computer. Suddenly the log on picture shows on the screen, but the computer says the user information is unavailable and won't let me log in!
This sounds like a failed update. Restart the computer and hit either F2 or F8 or possibly Tab or Delete once the splash screen comes up. This should give you a windows startup option for safe mode. Click Safe Mode with Networking and let the computer startup. This will bypass all current startup items and possible problematic services. Login and start up Task Manager. View startup items and look to see if anything is starting up that says "Windows Update" or if anything else stands out that shouldn't be there. Names that are random garbled letters, etc. Disable these for normal startup. Now click on control panel under start menu and go to windows update and see if any updates failed to install. If they did, disable install automatically in windows update.
After this go to "run" and type in msconfig. Click normal startup, hit apply, when the message that says "restart computer" pops up click yes and let it restart the computer normally.
Sep 09, 2014 | Microsoft Windows Vista Business Edition...
I cannot get passed the Windows Error Recovery screen. If I select Launch Startup Repair nothing happens. If I select Start Windows Normally it goes to starting windows screen momentarily and returns to...
First try starting your computer in safe mode. Power down, then hit power button and tapping F8 will get you to this option window. You can also choose safe mode with networking. While in this mode check for any new updates. If you installed new software or hardware uninstall these. Try restarting computer. If this doesn't work and you have a recovery disk put it in while computer is on and then restart.
Apr 27, 2013 | Gateway NE56R10u Laptop
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
Screen black on reboot
start the computer and when the computers splash screen shows (dell) etc. tap the F8 key repeatedly until you see the multiple startup choices. Scroll to "safe Mode with Networking" and select it, you will see the operating system listed as the target operating system, click that (hit enter) start in safe mode. When it boots do you see the screen with no problem? if so then the resolution may be wrong on the normal start up. On the dektop in a clear area free of icons, right click and scroll down to properties, click on settings, then move the resolution slider to either 800 X600 or 1028 X 768. click on yes to change the settings, restart the computer by hitting start > Turn off computer > restart. Reboot it normal mode (just let it boot as you would normally) If you can see the screen, you are all set, if not there is another issue to deal with.
Sep 03, 2009 | Computers & Internet
Error code stuck key and now it switches itself off
Check if system is booting in bios. Disconnect external peripherials except keyboard and mouse.Restart the system in safe mode,Do msconfig,disable startup and non microsoft services.If issue persist ran a diagnostics on memory and harddrive. Try to start system using 1 memory module at a time if you have 2 memory modules.reseat memory module and check.
Aug 18, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Cannot start in normal mode without blue screen popping up
Duing the startup, can you hit F8 just after the bios shows. You should see a list. If you choose, last known good configuration, what happens? If it blue screen's again, can you startup in safe mode? This is also a item on the list from F8.
Did you install any drivers recently, in the last day or two?
If so, when you boot into safemode, uninstall that driver and try to boot to windows normally.
Jul 28, 2009 | Acer Aspire One PC Notebook
Acer will not boot up,it keeps going back to asking the option of safe mode or startup normal screen.
This is a multi/complicated issue. I suspect your msconfig was changed and a checkbox is unchecked. I would startup in either safe or regular mode.
Then when in Windows, Start, then RUN
Type msconfig and hit OK
A screen will open up with a bunch of TABs at the top.
Select BOOT.INI one
When the scren opens you should see 5 check boxes on the left.
Make sure all of them are blank.
Say OK and APPLY and reboot
That should stop that other screen coming up.
Jul 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Black screen on my Acer Aspire 3680
when you start the pc tap on the f8 key and choose safe mode from the menu then hit enter twicw, if your pc will start up in safe mode, then you can click start, then type MSCONFIG in the search box and hit enter ( or click start,all programs,accessories,Run, then type msconfig and hit enter) if you click on the startup tab, you can see everything thats checked is starting with windows, you ca uncheck all of these, and by repeating the steps above, check them back one or two a time, until you find the offending program. Google pacs-portal.com for an excellent site that will tell you what all the startup entries are and if you need them
Mar 30, 2009 | Acer Aspire 3680 Laptop
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Acer 3002LCi ZL5 Sempron 64bit 2800+ (AC3002LCI) PC Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
