Question about Whirlpool Washing Machines
My Whirlpool AWM 8143 washing machine is showing what i assume to be an error message. On the screen it says "FP" and a number of lights are flashing. It has stopped miss wash and of course the whirlpool system support call centre is closed! Please Help.
The drainage pipe was blocked so I simply un-clogged it and made the machine drain and it all seems to be going well. Cheers.
Posted on Aug 03, 2008
What does it mean when 'FP" is displayed to my washing machine (Whirlpool AWM 6125) ??
Hello & Welcome to FixYa
PF or FP error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | Washing Machines
Whirlpool AWM 8143 - Starts a cycle and then starts flashing open door light and won't go further. Door is shut properly. Tried turning it off at the power and back on to no avail.
This is either a problem with the door lock itself or most probably a motor failiure as the door open light also indicates some kind of motor problem. If your appliance is 4/5 years and above then you will most likely need to change the set of carbon brushes on the motor and this will solve your problem
Jan 18, 2011 | Whirlpool AWM8143 Front Load Washer
Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Dec 29, 2010 | Washing Machines
Describe your AWM 8143 motor noise
once your motor ahs gone mate that's it, you need a new one!!
May 25, 2010 | Whirlpool AWM8143 Front Load Washer
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Washing Machines
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Feb 24, 2008 | Washing Machines
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
370 people viewed this question
Dan Webster
Dan Webster
Sal De
