Question about Watches
The second hand of my ck post minimal watch jumps only at every four seconds. What could be the problem? This happened after i tried to adjust the time.
SOURCE: Second hand skips
It's part of the design. this let's you know it's time to change the battery.
Don
www.finewatchmaking.com
Posted on Oct 12, 2007
SOURCE: Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
Posted on Dec 01, 2007
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
SOURCE: my Tissot Watches second hand jumps 3-4 seconds bursts.Why?
The second hand jumping three or four seconds .I have had this same problem and found out that its i sign of wanting a new battery.Mine is now perfect
Posted on Feb 26, 2010
I just bought a Gucci 8905 YA089303 and the second hand jumps about every 4 seconds. Is this fixable?
You are witnessing what is called the EOL or end of life indicator. Relax, it's your battery not you! Better watches have this feature. You will notice the time remains correct even if the seconds hand jumps 4 seconds. Some watches it is 2, some 3 seconds.
Mar 16, 2011 | Gucci 8905 Mens YA089303 (18965)
The movement on the second hand is jumping every 5 seconds instead of every second, however the time is still correct.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Oct 13, 2010 | Omega Seamaster 2561.80 Wrist Watch
My Tissot Watches second hand jumps 3-4 seconds bursts.Why?
Jan 24, 2010 | Watches
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Jan 04, 2010 | Wittnauer Laureate 12R12 Wrist Watch
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
Navy Seal Luminox watch second hand problem
It is a feature of this watch, it is referred to as the end of life (EOL) feature, it is a way of letting you know its time to change the battery before it dies to the point where it cannot keep time anymore
Oct 24, 2008 | Navy Seal Luminox Dive Watch
Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
Apr 14, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
458 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
