Question about Honeywell Heating & Cooling
What is a compatible replacement thermostat for honeywell T8082A 1148...2 zone gas baseboard heating system
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
SOURCE: Honeywell electronic thermostat malfunction for oil heat zone
Try changing the batteries.
Posted on Mar 04, 2008
  • 15 Answers
SOURCE: Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Posted on Jan 26, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T86F thermostat (controlling oil-fired hot water baseboard heat system) comes on on demand but will not cycle back on after zone cools - or it just takes too long???
T-Stat started smoking when activated last night. I swapped it out with one from another zone and have ordered a replacement. - www
Nov 24, 2009 | Honeywell Heating & Cooling
Want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
One zone not working; another is partly working
i would check my water pressure on boiler sounds like lack of pressure or air in system they can be related. if you have bleeder on baseboard try to bleed.
Feb 20, 2009 | Honeywell Programmable Thermostat Heater
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Oct 23, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
