Question about HP LaserJet 4240n Card Printer
My HP LasertJet 4240n will not do anything or allow anything. Its control panel says: Downld file now RFU LOAD ERROR RESEND RFU OVER PARALLEL PORT If I hold the Checkmark button when it's starting up I can get it to give me some menu items, like "Select Language", no matter which I pick it goes to the RFU error message. I can't ping it at the IP I specified for it (long ago) and I can't FTP to it. So, how do I clear the RFU error message so I can fix it? How do I get it back to having a good firmware?
  • Eli Doran Mar 22, 2011
    Thank you for the starting tip. :)
    I can read the message and understand what it is saying.
    I have the firmware ready to install.
    I know how to FTP to it and push the firmware file.
    However, now that this message is showing, the printer does *not* respond via the network. I can *not* ping it at the IP it has had for the last few years. I can *not* access its webadmin page via HTTP.
    When I start it and hold the Checkmark button it will give me some menu options, and no matter what I select, it goes to the RFU error.
    I found some instructions to clear the RFU error message so it will start responding and allow the firmware install. However, they don't work. It said to hold Stop while it was starting up. That did nothing for me. Holding Checkmark does bring some menus, but, now the ones with "Clear RFU Error".
    So, the installation instructions do not address the issue I am having. No where does it say "If you currently see a RFU error message on the control panel, then do this....", Or, "If printer is no longer responding to FTP, HTTP... then do this ..."
    This was the solution.
    I had to get 3 computers to get it to work because my first one did not have a parallel port, the second didn't work, fortunately I tried a third and it worked fine.
    * installed driver on machine
    * added printer
    * did the copy command to put the file onto the printer
    * it did its thing and I was all set.
    Thank you very much
  • HP Master
  • 19,396 Answers
Hi.
Download and reinstall the firmware. That is what the printer is asking for.
First download the firmware here: Firmware. The link is the standard firmware download for 42xx up to 4350, USA version. It covers the 4240n.
For installation follow thoroughly the instructions on this page.
Regards.
Ginko.
Posted on Mar 22, 2011
  • Ginko
    Ginko Mar 22, 2011
    Hi.
    When you get the error message you need to update using parallel port, as explained here:
    Remote firmware update through a local Windows port.
    Get a parallel cable.
    Download and install printer drivers if needed (install as local printer).
    Do the upgrade using LPT1 connection.
    If the computer does not have parallel port, find an older computer, or get an adapter like the ones in this page.
    Regards.
    Ginko.
  • Ginko
    Ginko Mar 22, 2011
    Hi.
    Good to know it's done!
    All the best.
    Ginko
Send RFU file
we can't instal the driver because computer cant sport the usb
Feb 29, 2012 | HP LaserJet 5200 Printer
What can I do to my printer is sending me this message "Downld file now inflate failure Resend RFU over parallel port"
For whatever reason your printer is trying to do a firmware upgrade and it isn't working. If this came out of the blue, you may have to replace the formatter. RFU = remote firmware upgrade. If you caused the problem while trying to upgrade the firmware, try it again
Sep 02, 2011 | HP LaserJet 9050n Printer
Hp 5550 color laser printer display "downld rfu error over parallel port" how can i get a solution? and what is the cause? thanks
Appears like someone tried to upgrade the firmware.
While the firmware was being downloaded, something interrupted the process. For example somebody tried to use the printer, you had a power problem, your internet went down etc, etc.
You are going to have to try the firmware upgrade again.
If you can't get passed the RFU error, you will probably have to get the formatter replaced.
Aug 19, 2011 | HP LaserJet 5550 Printer
Hi i have an hp CLJ cp3505n it has sopped working, error downld file now send rfu upgrade
Please see my tip. It was written for the CM2320 but the procedure is basically identical for all HP products.
May 07, 2011 | HP Office Equipment & Supplies
How to remove downld file now send rfu upgrade on usb dev port error in hp laser jet p4015 printer.
Hi sachin_kanoj !
If it's a unwanted download , it's a malware . You will get rid of it by downloading and launching Malwarebytes from : http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10896905.html
If it's something you volontarily downloaded and installed in your printers software , you need to go to the
Control Panel \ Programs , delete the software and disconnect your unit .
Reboot . Reinstall sofware and reconnect the printer .
I hope this will help .
Best regards ,
fanaudi .
Feb 23, 2011 | HP LaserJet P4015N Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
Jan 05, 2010 | HP Office Equipment & Supplies
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Feb 27, 2009 | HP LaserJet 5550 Printer
Printer Froze and Have Download Message
Downld File Now
RFU LOAD ERROR
RESEND RFU OVER
PARALLEL PORT
Aug 13, 2008 | HP LaserJet 5550 Printer
HP LaserJet 4240n Card Printer Logo
338 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
