Question about Hotpoint Refrigerators
Have Hotpoint ff53 frostfree frig freezer. Freezer o/k, but frig part not getting cold, have replaced all thermistors.
The Duff Man
  • 3 Answers
SOURCE: Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Posted on Jan 22, 2009
  • 378 Answers
SOURCE: Freezer works fine but frig does not get cold at all
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Posted on Apr 03, 2009
  • 531 Answers
SOURCE: side by side frig./freezer not getting cold-
check defrost
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: freezer fan not running
Often times the defrost termination switch (which opens when it gets warm enough) will hold the fan off until it closes again when the freezer runs. It is possible that the switch is not closing, but be sure the freezer is getting cold enough for it to close.
You know the freezer is likely cold enough when you see frost covering the entire evaporator coil after a few hours of operation. A partial frost pattern could indicate low refrigerant, or a restriction of refrigerant.
Posted on May 29, 2009
  • 363 Answers
SOURCE: freezer cold ,no ice frig warm
replace the evaporator fan motor
Posted on Jul 30, 2009
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
I have a hotpoint fridge freezer model ff92ys the freezer is running ok but the fridge isnt cold enough i try to set it at +4 but it just sets itself back to +20 please help
The thermistor has probably failed. I had the same problem with my FF92s fridge/freezer. I replaced the thermistor and hey presto it works again.
The thermistor is loacted behind a removable panel inside the freezer section of the fridge/freezer. You also have to remove a polystyrene cover and a further metal cover to get tp the thermistor. Pull the metal cover from the left as it has wires attached to it on the right hand side. The thermistor is available to buy online, just google it.
Feb 05, 2010 | Amana ABB2227DE Bottom Freezer...
I have a hotpoint frostfree freezer that is over
Since this is a frost free refrigerator/freezer, you shouldn't need to defrost it, and the frost should not be building as you describe.
If your OK with diagnostic troubleshooting techniques, and have a volt-ohm meter and know how to use it, we can figure out whats wrong with your unit.
Dec 16, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint HTS15BBMFRWW refrig isn't staying cold freezer seems fine I can't detect the fan running at all. Replace fan motor??
Yes, if your freezer is cold but fan is not circulating cold air into frig compartment then you should replace it . You will have to take off back panel of freezer to access it but is easy to replace. Hope this helps
Jul 29, 2009 | Refrigerators
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
I have a GE side by side refrigerator GSH22JST and frig is cold but freezer is not cold enough (soft ice cream)...heavy frost is building up on bottom half of evaporator. I can force defrost mode through...
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
nguyen@ite.net
Jun 09, 2009 | Refrigerators
Freezer fan not running
May 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Whirlpool Frig
Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
Mar 16, 2008 | Refrigerators
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Refrigerators Logo
59 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
