Question about Lands Phones
Cannot get a ring tone when receiving phone calls
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Posted on Jul 29, 2009
4 Suggested Answers
SOURCE: I HAVE A PANASONIC PHONE
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Posted on Feb 25, 2008
consultel1
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
SOURCE: Can't change ring tone on Panasonic KX-TCA175
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
Posted on Jul 28, 2010
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Lands Phones Logo
248 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
