Question about Tally T6212 Matrix Printer
We have a Tally T6212 printer. First problem: seems that we're failing ribbons, a lot, lately. Removing the ribbon shows that it had stopped advancing. Second problem: printed product shows "dragging" marks mostly on the right half of the sheet (wide tractor). We can't find our manual for it and are officially lost. Does the lever on the left side have any impact on this? The manual would help. Please contact soon.
itdude4321
  • 13 Answers
SOURCE: TAKE UP RIBBON
I work with Zebra printers daily and I have found several ways to enable a stuborn ribbon motor. The S300 is the hardest to turn on but unless the belt has broken or come off it can be done. The S400 and S600 are much easier, below are a couple step that work for me.
Enabling/Disabling the Ribbon motor
Turn off the printer.
Disabling the motor – Press the FEED, CANCEL and MODE buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out.
Enabling the motor – Open the printhead and retract the ribbon completely onto the supply spool. Leave the printhead open. Press the PAUSE, FEED and CANCEL buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out. When the printhead light begins to blink, reinstall the ribbon and close the printhead.
The printer may or may not print out a ribbon sensor profile, this is normal. Cycle the power and you should be good to go.
Posted on Mar 30, 2008
  • 84 Answers
SOURCE: Tally 2250 Matrix printer
try to replace the ribbon or check if its properly inserted.
Posted on Jul 21, 2008
  • 114 Answers
SOURCE: Tally T2250 showing an error..
If you are using re-fill ribbon then the problem may arise , if you are using original then clean the encoder strip with isopropile if not solved change the encoder strip .
Posted on Feb 01, 2009
SOURCE: "check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Posted on Mar 21, 2009
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
Showing Ribbon Fault
hi
clean the ribbon then if still same error chang the ribbon
Jun 19, 2011 | Tally 6312 Matrix Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
Ribbon Stall
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ... ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ...
www.printersupplies.com/errors.html
Dec 03, 2009 | Office Equipment & Supplies
Ribbon failure
Not wright installed. Only Course
Jul 11, 2009 | Tally 6306 Matrix Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Tally T6212 Matrix Printer Logo
62 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
mohamed salim shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
