Question about Stoves Kitchen Ranges
My model is similar to the one selected and is in my motorhome The home is now on its spring clean before being put back on the road My gas is on and is reaching the manifold which splits up to 4 locations All 4 valves on the manifold are in the open position The hot water is on, the fridge is on, the central heating fire is on, but the stoves cooker is not getting a gas supply Is there an air lock and if so, how can I clear it I have been holding down the buttons on the cooker for quite a few minutes without success Am I missing another stop valve somewhere The van is an Ace Firenze, 2006 model
  • 79 Answers
SOURCE: maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Posted on Jul 05, 2008
Jimster
  • 240 Answers
SOURCE: Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Posted on Nov 16, 2008
SOURCE: Hoover Steam Vac clean water tank valve leaks
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
  • 68 Answers
SOURCE: no water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Posted on Dec 26, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Stoves Newhome SI550DOm gas cooker
This is a common safety feature, and is based upon the main gas valve inside the appliance. It regulates only a tiny ammount of gas through when closed - enough to light a pilot. This should then heat a component high enough to trigger the main gas valve and light the main burner.
With the door fully open. Turn on the oven and watch the pilot ignite FROM THE OUTSIDE. Look to see that it is heating what looks like a small wire in the flame. If it is not. Turn it off and let it cool.
You need to adjust this into the path of the flame just by bending it a little. Then try again.
If you cannot, or adjustment doesn't work,then you really need a replacement main gas valve - which is a registered appliance specialist job I'm afraid. Don't take chances with gas appliances.
Thank you for using Fixya.
What is the wheel base of a 2005 Georgie Boy Pursuit 3500 DS
variable on version
[PDF]2005 ® - Colton RV www.coltonrv.com/wp-content/.../2005-Georgie-Boy-Pursuit-Brochure-Colton.pdf
  1. Cached
Presenting the new 2005 Pursuit line from GBM-"the motorhome people."® ... back roads and bayous in his Georgie Boy motorhome on a savory quest for "true Q." .... 2970 DS. 3180 DS. 3500 DS. Chassis. Ford. Ford. Ford. Chassis Model. F-53 ... 6.8. Wheel Base. 190". 208". 228". Tire Size. 225/70R 19.5. 225/70R 19.5.
wheel base of 2005 Georgie Boy Pursuit 3500 DS Google Search
Jun 23, 2018 | Cars & Trucks
Domestic fridge/smell in motorhome when on gas
check burn tube and gas pressure also check for lint or debris in back
Jun 17, 2018 | Dometic Refrigerators
Have a Mr Coffee model #BVMC-PSTX91. The filter basket has a spring loaded release that has fallen off - how do I put back on? cannot figure out how to put the spring and extra plastic piece on?
without seeing it (a picture) that is a difficult question to respond to. it may have possibly broken or a piece of plastic needed to keep it in place broke - or the spring is defective. suggest get a new basket. (or go to the store, or find a neighbor with a similar model - and look at his basket, take a pic of the spring mechanism with your cellphone and go home to fix your own.)
regards,
Jan 27, 2017 | Coffee Makers & Espresso Machines
1993 ford f150 shut off driving down the road at 60mph would turn over but not start until after beating on the gas tank and jiggling gas line hoses out of tank truck started and i got it home any ideas...
check the wires on the feed to the fuel pump ,,also check that it hasnt got the cut out thingy on top of the fuel tank like the ford explorer,unless this is only fitted on the europeon models .?
Aug 14, 2017 | 1993 Ford F150 SuperCab
MTD push mower starts but runs poorly
take the bowl off the bottom of the carb and see if there is fuel varnish in it. If so, clean the bowl and carb to remove varnish, which is what old gas can leave as a residue for sitting too long.
May 01, 2017 | Garden
Looking for a 78 dodge motorhome manual
You may be able to locate one in a used bookstore- online or bricks and mortar. Anything common to the truck body, frame, suspension engine and driveline, are going to be the same as the conventional counter parts. 1977 and 1976 data should be comparable. 1978 was the year they got the bailout and 1979 models were pared back considerably to just the 1 ton and smaller trucks.
Essentially what you will want to look for is Chassis Cab truck manual for the series you have- 200/250, 300,400, 1976 through 1978 and it will give you the breakdown of everything truck/automotive. It is highly likely the company that put the motorhome body on the chassis went out of business, so you are not going to find topics on body sheet replacement, refrigerator setup or stove setup. Those you can look at modern appliances and make accurate inferences on the installation. Water heaters have changed since 78, so information on the older tanks will be similar to what a home installation would be.
Details on the gas pressure are going to be the same as they were, and that data should be found on the refrigerator, the heater, and possibly the water heater, and once in a while near the tanks themselves.
Apr 06, 2012 | Cars & Trucks
1984 midas palm beach class a motorhome will not start
should be under the motor home along the frame follow the fuel line
May 29, 2017 | RVs
Checking engine light maybe tranmission driving home all of a suddenly it shifts to may 1 gear going 20 milles hour. Then I stop and i put it in N I let it running then I put in ...
When you get a check engine light it means a fault has occurred and a fault code for that is in memory, now you need the fault codes or codes read to see what is going on and then troubleshoot the system.
Apr 13, 2017 | 2003 Honda CR-V
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
Throttle linkange spring connection
goe to briggs and stratton .com and put your model type and code it will bring up your diagram and that will help.
Jun 27, 2009 | Garden
Kitchen Ranges Logo
37 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
