On my Lexmark 5800 series. I press print, I receive the following message: Alignment problem 1) Remove tape from cartridges. 2)Check Paper. 3)Press OK to retry. I've done all three repeatedly.
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My printer error message indicates-
    Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
    Posted on May 03, 2011
    Printer keeps giving alignment problem message
    hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
    hope that helped, best regards
    Feb 28, 2014 | Lexmark International Lexmark 7300 Series
    Brand new ink cartridge for Lexmark X3650. Error message to remove tape from cartridge. Tape has been removed. Print alignment prints in only black and same thing on cleaning process.
    You can try to manually wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. You can also clean the nozzles using the Lexmark software on your computer. If you're using Windows, go to Programs/All Programs > Lexmark 3600-4600 Series folder > From the printer folder, click Maintenance > Clean Cartridges > Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
    May 27, 2011 | Lexmark X3650 Printer
    My printer error message indicates- Alignment problem.(1) Remove tape from cartridges.(2) Check Paper.(3) Press Ok to retry. I do not see it being easy to remove tape from cartridge,but my allignment paper...
    Apr 11, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    How to change the black ink cartriage
    User guide available for free from here
    http://www.intel.com/support/chipsets/sb/cs-009236.htm
    Go to page 69 for clear instructions
    Mar 06, 2011 | Lexmark X7350 InkJet Printer
    My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
    To improve print quality
    1 On the operator panel, press Options repeatedly until
    Cartridges appears.
    2 Press the right arrow button until Align appears, and then press
    Select.
    An alignment page prints. Once the alignment sheet prints, your
    automatic alignment is complete.
    You may need to clean the print cartridge nozzles.
    Using the operator panel
    Load paper in the All-In-One.
    2 Press Options until Cartridges appears on the display.
    3 Press the right arrow until Clean appears on the display.
    4 Press Select.
    A nozzle page prints forcing ink through the nozzles to clean the
    clogged nozzles.
    5 Print your document again to verify your print quality has improved.
    6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
    7 If print quality has not improved, try cleaning the print cartridge
    nozzles up to two more times.
    Using the Lexmark X5100 Series Solution Center
    Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
    3 Click the Maintenance tab.
    4 From the Maintenance tab, click Clean to fix horizontal streaks.
    5 Click Print.
    6 Print your document again to verify your print quality has improved.
    7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
    8 If print quality has not improved, try cleaning the print cartridge
    If the print quality does not improve after cleaning the print cartridge
    nozzles, dried ink may be on the nozzles or contacts. To wipe the print
    cartridge nozzles and contacts:
    1 Remove the print cartridges.
    2 Dampen a clean, lint-free cloth with water.
    3 Hold the cloth against the gold nozzle area for about three seconds.
    Gently blot and wipe dry in one direction (this prevents the colors in
    the color cartridge from mixing).
    4 Remove the old cartridges
    5 Let the nozzles and contacts dry completely.
    6 Reinstall the print cartridges, and then print your document again.
    7 If the print quality has not improved, try cleaning the print
    8 If print quality is still unsatisfactory, replace your print cartridges.
    Hope this helps.
    Thanks
    Have a good day.
    Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
    How do I align ink jets?
    Microsoft Windows 95/98/Me:
    (Applies to all printers)
    1. Click Start, Programs, Lexmark Series.
    2. Click Lexmark Control Panel.
    3. Click Print Cartridge installation.
    4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
    5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
    6. Insert the print cartridge into the print cartridge carrier.
    7. Push the cartridge back until it clicks into place.
      • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
    8. Click the appropriate Cartridge Installed option in the printer software.
      • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
        1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
        2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
        3. Click OK.
    9. Close the front cover of the printer.
    Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
    Color cartridge stopped working.
    Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. If that does not work, the nozzles on the color ink cartridge may be clogged with dry ink.
    There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
    If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means.
    It nothing works, replace the color ink cartridge.
    Apr 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
    How to change lexmark Cartridge
        3. Click OK.
    Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
    I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
    is this a pc or mac?
    for windows general make sure you folowed these steps:
        3. Click OK.
    Dec 01, 2008 | Lexmark Office Equipment & Supplies
    Cartridge problems
    Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
    Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
    173 people viewed this question
    k24674
    jasbo
    jasbo
