Question about Hannspree HF237HPB 23 inch LCD Monitor
Hello. I have 2 Hannspree HF237 monitors. They each have this issue: When my display has gone dark after disuse (usually after 45 mins or so), and also when I wake-up my computer first thing in the morning, I can hear that my computer is waking up but the monitor display doesn't. When I tap the keys or move the mouse, the display is still dark. I have to turn the monitor off and then on, keep clicking and shifting the mouse and keys and eventually the display comes on. This is a progressive problem. My first monitor started doing this and eventually did not respond at all. Now I am on my second one and, while it started up fine in the beginning, it is now having the same problems as the first. Any ideas? Thanks for your help!
  • ksullivan112 Mar 22, 2011
    I just tried it and it made my screen go dark. I pressed it again and it restored the display. Pressing the power button usually cues my computer to shut down (my MAC provides a prompt: Do you want to shut down your computer now?) but it didn't this time. Do you know why?
    Genius:
  • 1,570 Answers
Hi
When your computer comes on black screen, just press the power button of your CPU and it will start displaying the monitor.
Post comment if you need more help or if solution not working.Regards
Posted on Mar 22, 2011
  • Benjamin Jr Singson Mar 22, 2011
    If this still problems, I believe you need to update the monitor driver because when you installed it using your monitor driver CD, it get outdated and sometimes your computer gets awry. Just gets the latest monitor driver updates and installed it that compatible with the operating system.
  • Benjamin Jr Singson Mar 23, 2011
    Hi
    Try also to go to BIOS SETTING MENU by press F2 o Delete when start up booting and choose the power menu. Then choose WAKE UP PS2 KEYBOARD and save & exit. When you computer go black screen, use the keyboard to get display on your monitor.
    Regards
How do I reset to factory settings?
here is the user manual http://www.manualslib.com/manual/64813/Hannspree-Hf237.html hope it really helps hoping to hearing from you
Ialso recommend registering to the best site for earning money online http://www.clixsense.com/?8516905 I recently found and please do that I you find me helpful hahah
GOOD LUCK
Mar 24, 2015 | Hannspree HANNS Computers & Internet
When I boot my computer My HF237 monitor will briefly show the page then go dark. How can I diagnos the problem?
This is usually an issue with a failing capacitor. I replace them in mine often. In the monitor, on the power supply will be several capacitors (caps). Look for the tops to be domed these are bad. Try a site called badcaps if you are game to replace these.
A soldering station after shipping can be as low as $32 or so.
Oct 09, 2014 | Hannspree HF237HPB 23 inch LCD Monitor
How to fix HF237 Hannspree Monitor?
I did a quick Google search, since I experienced the same *2 seconds to black* problem months ago, and found this Hannspree HF237 2 seconds to black Badcaps Forums
Sep 01, 2014 | Hannspree HF237HPB 23 inch LCD Monitor
MY HANNSPREE MONITOR HF237 SUDDENLY WILL NOT STAY CONNECTED TO MY LAPTOP I JUST HAVE A BLACK BLANK SCREEN. I AM USING WINDOWS 7 ULTIMATE
On laptops there is a key sequence that you can switch between monitor states, it's possible you have it in Laptop screen only. Look for the "Fn" key and then hit the Monitor button (it has a picture of a monitor) usually this is somewhere around F5 or F8.
May 19, 2011 | Office Equipment & Supplies
My hannspree hs257hps monitor keeps going dark after a short period of time. I can turn it off and on and it works for a while but after a few minutes it goes dark again
backlight inverter is loose or bad.. dissasemble and check..shile a light on it while it is dark , but still on ..just like you would with a laptop
Jan 10, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
NEED DRIVERS FOR VISTA 32 BIT FOR MY NEW HF237
find your driver from these site
1)www.nvidia.com/object/winvista_x86_100.64.html
2) www.rage3d.com/board/showthread.php?t=33863938
3)
Oct 03, 2009 | Hannspree HW191D LCD Monitor
Hannspree HF237 23" Monitor
The driver files allow for windoze to set the monitor up as a plug-n-play device. However, you do not need drivers to set this up manually. If you will right-click the desktop and open the display properties, click the display adaptor tab, and uncheck the box that indicates to hide incompatible settings (I don't have windoze myself, but it's worded something like that) save that change and click on the monitor tab, then find a compatible setting for your monitor as indicated in the instruction manual, you can set it up to work as well as if it had the drivers.
If you have any questions, please ask.
Aug 06, 2009 | Hannspree HW191D LCD Monitor
Error on monitor: Input signal out of range. using VGA cable and laptop is right next to monitor Hannspree 23" HF237 LCD monitor
Hello mcarsten,
Your monitor may not be configured to the correct resolution for the second monitor. If you right click on an empty space on the desktop and then select properties, the display properties will appear. Click on the last tab on the top right. It should be settings or something like that. You should see two boxes with the numbers 1 and 2 in them. Next click on box number 2 and try using the slider below and changing it to different resolutions for your monitor.
Hopefully one of these should work for you.
Jul 10, 2009 | Hannspree Computers & Internet
HP Pavillion DV9700 Display does not work (it is dark)
its a hardware issue the proble may be on the cable that gives display to the screen or your screen has gone
Jun 13, 2009 | HP Pavilion dv9700t Notebook PC
Hannspree HF237HPB 23 inch LCD Monitor Logo
209 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
