Question about Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan
My nutone qt140l fan does not seen to exhaust very well. what should i do
  • 95 Answers
SOURCE: Nutone 30 year old exhaust fan blower
This site has a form to help find parts.
http://www.centralvacuumstores.com/fan_help.php
I check NuTone's page, http://www.nutone.com, and they do not have that model number listed.
Posted on Oct 02, 2009
  • 234 Answers
SOURCE: NUTONE FAN 8310: WHAT IS THE
It does not matter whether the power goes to the fan unit or to the switch box, you still need 3 insulated wires going between the switich and the fan, and the ground wire as a 4th wire. If power is at switch, you will have white as nuetral feed to fan and 2 blacks (or a red and a black) one each to bring power for light and power for fan or heater element. ( if so equiped). If power is to fan unit, the white wire must have a piece of colored tape (red, orange, blue, brown) and this whtie wire is attached to the black power wire. The tape shows that this is not a neutral. The tape has to be at both ends of the white. Now, the other 2 wires (blk & blk or red & blk) can be atteched to the switch and carry the elec. to the fan light, blower, and or heater. Goodluck, Macgivor
Posted on Jan 02, 2010
SOURCE: Problems with exhaust fan NuTone Model LS 100SE
The C-frame motor for LS100SE (P/N 62345) is no longer manufactured, and no replacement is specified. I checked with Nutone customer service if the motor for LS100 (P/N 89169) will work. They said the blower housing is the same between the units, so it should work mechanically, but the plug configuration is different requiring some electrical changes.
Posted on Aug 17, 2010
heatman101
  • 43501 Answers
SOURCE: I have a nutone 8830
Take down the cover... they usually snap in by a set of spring wires...then looh ofr a screw or a couple of screws that hold the motor assembly up in the box. If there are no screws then the plate that holds the motor just snaps into the outside box....if that is the case just take a screw driver and pry out slightly on the outside box and snap the plate out and drop it down...
The motor will then just be a couple of nuts to release it from the plate...the fan cage often just pulls off of the shaft.
heatman101
Posted on Oct 09, 2010
  • 185 Answers
SOURCE: I need a replacement motor
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Posted on Feb 24, 2011
I need a replacement motor for a nutone fan ls100se
Try Home-Depot replacement fan kit or www.electricmotorwarehouse.com/aosmith/nutone/nutone.htm
Sep 16, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I would like to replace a Nutone 8663Rm series bath exhaust fan with a Broan 683L The 683L requires an opening of 8" X 8 1/4". Since access it is located in the attic, where it is unbearably...
You can buy a replacement motor assembly for that model.
http://vacuums-intercoms.centralvacuumstores.com/search?w=8663rmsa&af=type%3Aproduct&asug=&x=0&y=0
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rmsa&Search.x=0&Search.y=0
Jun 16, 2011 | Broan-NuTone N-8663RMSA Combination Light...
My nutone qt-110n-b is louder than usual and I seem to have a loss of exhaust.
Sounds like you need motor replacement assemblies. take a look on amazon for it. Amazon com nutone qt 110n motor. Hope this was helpful. cheers
Mar 06, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Fan is making ratteling noise.
pull off cover and check fan for a loose bearing. "will wobble if it has a loose bearing". if not a bad bearing then tap on moptor housing while on and be careful not to touch a fan blade. then replace cover in reverse. :)
Sep 21, 2010 | Broan-NuTone N-QT140L Combination Light...
Can not find motor for LS100SE . ref p/n 62345000 given by Nutone
Packard Electric Motor Company model # 65345 is a direct replacement motor for the nutone LS100SE. It can be ordered from Conrey Electric Inc in Portland OR.
Aug 13, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Feb 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan Logo
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
