Question about Car Audio & Video
How do i install my american pro bass machine model vs 1405 i need to know how to wire it up with memphis 10 in sub woofers
Cerfer39
  • 709 Answers
SOURCE: wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Posted on Nov 27, 2007
  • 631 Answers
SOURCE: sub woofer wiring
If you have a 500a2 and two 4 ohm single voice coil speakers, you have only one option. Connect one speaker to each channel.
Posted on Dec 30, 2007
uge44
  • 226 Answers
SOURCE: i dont know which wires
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Posted on Nov 20, 2008
hack124x768
  • 33 Answers
SOURCE: jbl bass pro volume
Bandpass box calculator. Have fun.
http://www.colomar.com/Shavano/4thorder_info.html
Posted on Mar 17, 2009
  • 84 Answers
SOURCE: dont have wire schematic to hook up american pro
You should go to www.the12volt.com they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to crutchfield.com and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Posted on Jun 14, 2009
How Do I wire my American pro bass machine model number vs 1406 limited edition 4-channel amplifier in Bridged mode
You can bridge 2 channels, Not 4. The individual channels will fight each other and one will cook...
Jul 16, 2015 | American Pro Car Audio & Video
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Hooking up the speakers
Well, this means you have dual voice coil subs. These subs are for running one sub in stereo mode( meaning you can hook up a right and a left channel to one speaker). In your case you are using 2 subs, which all you have to do is run a jumper wire from one side of the sub to the other. Take your (+) and hook it up on the (+)on one side of the sub and take your (-) and hook it up on the (-) on the other side and run a wire from the remaining post to the other. And do the same thing on the other sub.
Aug 09, 2009 | Blaupunkt Memphis MP66 CD Player
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Car Audio (amp over heating)
The problem would be if you had it switched around. The 1200W subwoofer only means that it can handle 1200w of power the 1000w amp means that it can deliver 1000w of power. What you may have is an impedance mismatch. My question is what is the resistance rating on the sub woofer and what is the minimum resistance rating of the amplifier. These are actully the important issues at hand. the rating of the subwoofer resistance in Ohms should never be lower then the minimum resistance rating on the amplifier. in fact the resistance rating on the amp should match the resistance rating on the subwoofer.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
