Question about Car Audio & Video
I have a 1996 ford explorer we installed a new radio the power works but no sound
    President:
  • 676 Answers
Hello my name is Israel and I will try to help. In the set of wires from the vehicle there should be a blue wire that need to be connected. Blue wire should be connected to a switch positive 12 volt. This will turn on the vehicle amplifier. Good Luck.
Posted on Mar 22, 2011
I am trying to install a ford factory CD/cassette radio ford part number XL2F-18C868-BB in my 1996 Explorer XL. Everything plugs in fine but there is no sound. I've checked the wire harness and everything...
There is a separate plug for the speakers, if you are replacing a non factory radio then maybe these speaker cables were re-routed to an amp. or something?
Jul 11, 2014 | 1996 Ford Explorer
Will a 2002 ford explorer stereo mount in a 1996 ford explorer
offcourse it will.You might have to change the connectorplugs these are changed all the time but you can just connect the wires one by one
Mar 16, 2014 | 1996 Ford Explorer
1996 Ford Explorer factory Radio works but when i install the aftermarket radio no sound comes out from it what do i do ..??
Does it light up? Does it have a mute button? Does it have a mute wire for in vehicle phone systems? If so, it may need to be grounded to take it out of mute, or it may need to go to 12 volts + It depends on how the circuit was designed.
If those check out, or it lights up but no muting make sure the speakers are connected to the correct wires. Also check to make sure the speakers are not grounded. Two wires should go to each speaker. you can check the condition of the speakers with a 9 volt battery touched across the leads, you will hear a pop sound. make sure those two wires for each speaker are connected to the radio correctly.
Jan 23, 2012 | 1996 Ford Explorer
I would to know whats radio code for ford farmont
Post the SERIAL NUMBER found on a label on the radio casing
Usuall begins with M or L or C
Jan 06, 2010 | 1996 Ford Explorer
Radio resets when I start up
Sounds like fuse gone that supplies constant power to radio. It has 2 power wires, (and fuses) one sends power all the time, and the other when key turned on. Check all your fuses.
Nov 18, 2009 | 1996 Ford Explorer
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
