Question about Sport & Outdoor - Others
I have a boston Whaler with a 25 hp yamaha 4 stroke, 2001 model on it. Engine ran fine in the river, brought it how and found the engine would not crank, absolutely nothing when you pushed the engine mounted start button. ** I disconnected the positive lead from the battery to the engine and started troubleshooting with an ohm meter. ** In the course of troubleshooting I noted that the 20amp fuse in the small black holder mounted below and to the rear of the solenoid had blown. **I replaced it with the on engine mounted spare. **When I started to reinstall the positive battery cable I noticed that there was obviously a current draw as there was some slight arching when the power cable contacted the positive battery terminal. **Since I have switched this motors controls from tiller steer to a wheel steer i have left the start switch on the engine but moved the kill switch and an on/off switch to the small center console. **Both the on/off switch and the kill switch were in the engine off position. **Other info: Obviously something is drawing current so i have left the battery unhooked. BTW the engine now does start and run when the starter button is pushed. I had noticed the day before that when i was test running the engine the evening prior to going out that my electronic tach stopped working. After noting the small sparks i tried disconnecting a few things and noticed the sparks stopped when the red wire to the ignition box was disconnected. ***Any clues as to what is wrong here??
bbtoast
  • 319 Answers
SOURCE: 1981 Corvette will not start
The neutral safety switch is located in the shifter housing.
Here is a link to a good article on this topic, that would beat an explanation from me.
Brian
Yes, it sounds like the NSS is the culprit.
Posted on Aug 04, 2008
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Posted on Nov 07, 2008
  • 1861 Answers
SOURCE: 1995 camry has no ignition fire
I think for sure that the timing belt has jumped a tooth. This can happen if your water pump, or your idler pulley, which are driven by the timing belt, "locks up" for a second. Best advice: replace the timing belt (you should not "reuse" it, as once it slips a tooth, that tooth is now weakend. Also, check the feel of the water pump impeller-gear...if it feels gritty or does not spin freely, replace the water pump while you are in there. It's not much more work. Also check the IDLER pulley for the same feel. If it feels bad/does not spin free, replace it. One or the other caused your problem.
Let me know how it turen out.
Posted on Nov 29, 2008
  • 225 Answers
SOURCE: 1100CC ENGINE KEEPS RUNNING ON 2 CLY. AFTER TURNING OFF
i would recheck wiring at stator.
Posted on Jun 07, 2009
  • 202 Answers
SOURCE: Have Exmark 52 LazerZ with Kohler ch25 engine.
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Posted on Jul 16, 2009
I have a 1995 Boston Whaler rage that I want to replace ignition switch. Any idea where I can get replacement?
Hello George
I have a 2014 Boston Whaler SuperSport 15. It is my third Boston Whaler.
You will get this from Specialty Marine in the link.
Marine Parts - Boston Whaler Parts - Specialty Marine
www.specialtymarine.com/Browse-Parts-By-Model-c11/Dauntless 16' - 1999-2006 · 16' Ventura - 2000-2003 · Classic 16'/17' - 1961-1976 · Classic 17' - 1977 - 2002 · Classic Outrage 17' 1990-1995 · 17' Outrage 1996-1999 · 17' Dauntless Dual Console 1995-1997 · Montauk 170 2002-2006 · 18' Ventura - 1998 · Classic Outrage 18'-25', 1978-1992 · Dauntless 18'- 1998-2006.
Bookmark 'Whaler Central' as it is a great resource. Also join the 'Everything Boston Whaler' Facebook forum. It is full of people that know everything about Boston Whaler, and it wouldn't surprise me if someone on it has a switch. A great group of guys.
WhalerCentral - Boston Whaler Boat Information and Photos ...
www.whalercentral.com/forum/viewthread.php?thread_id=23588
Mar 8, 2017 - 3 posts - ‎2 authors
Also see this Frequently Asked Question in our Main menu section on the Navigation bar at the top of the page. http://www.whalercentral.com/faq.php?...p?cat_id=8. Hopefully that will get you started. Maybe another member here with a Rage model can help answer any other questions you may have.
1995 Boston Whaler Rage replacement ignition switch Google Search
Apr 29, 2018 | Boating
I’m looking for a manual for a Yamaha J650C2 for a Boston Whaler jet boat
I have a Boston Whaler also! Join the Facebook Group 'Everything Boston Whaler'. The information found in there is priceless, and someone may well have everything for the Jet Boat. I know I have seem images of them and some of the 8,400 members have owned them. The group owner is Jeff Rohlfing. Tell him I sent you.
Nothing leaps of the page on Google looking for the engine.
Yamaha J650C2 jet boat Google Search
A search for the boat though shows it is the Boston Whaler Rage and does bring up some information.
Boston Whaler jet boat Google Search
Apr 22, 2018 | Yamaha Boating
25 hp evinrude e-tec I dewatered the engine but unable to dewater the fuel system it was underwater for about 1 week I had 3 lights on the control unit has it running for about 30 seconds
Put plenty of Fuel stabilizer in your tank which absorbs water back into the fuel as a suspension.. Try and remove every pipe in the fuel system and blow it through. Try and get it running with EZEE Start. Also check the plugs again and warm them up with a blowlamp before replacing them.
Google 'Boston Whaler' and 'Unsinkable Legend' :>) I filled the back of an 15 foot, 1986 Sport with water three times.
Nov 07, 2016 | Cars & Trucks
Why is my yamaha 2003 4 stroke 40 hp seem to be seized only 400 hr ran fine last time 3 weeks ago
Water pumps fail sooner from non use than using them all the time.13 years is a rather old unit
Oct 19, 2016 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
How can I loose speed when I changed my twins from 225 to 250 ,,,10 m.p.h.,, props good
There is a Facebook page called Everything Boston Whaler. There is a guy on there who is a prop expert if you fancy changing props?
Apart from that, were the previous engines two stroke? They have much more power for weight ratio. Your Optimax are heavier, but are much more economical and much easier to start.
I have a lowly Optimax 60 in place of an Evinrude 70 on a similar Boston Whaler. The new boat is slower.
Nov 18, 2015 | Cars & Trucks
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
I need the spark plug gap for a 2001 Yamaha 115hp 4 stroke outboard.
For a 2001 Yamaha F115 4 stroke use NGK Plugs LFR6A-11 gapped between 0.039 and 0.043
May 09, 2009 | Yamaha 12V Air Pump
Sport & Outdoor - Others Logo
54 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
