Question about Jensen VM9510 Car DVD Player
I need a wire harness for my unit - Jensen VM9510 Car DVD Player
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jensen Master
  • 2,226 Answers
Try audiovox.com. Audiovox owns Jensen now.
Posted on Mar 22, 2011
I need to find a manual for CD player
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness Manual ...
www.fixya.com/search/...clarion_pro_audio_cd7770_cd_7770.../manual
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness, manual related issues. Get free help, solutions & advice from top Clarion experts.
Oct 01, 2015 | Clarion Pro Audio Cd7770 Cd 7770 Wiring...
Tip
Never Cut The Stock Harness.
The best advise I can give and the worst mistake you can make while trying to install a new head unit into a car is DO NOT CUT THE STOCK HARNESS.
New head units come with bare harness with just wire ends, so you may think you need to cut off the harness on the car to wire it in.
This is the worst thing you can do. As a matter of fact, it is a bad Idea to cut any harness for anything in your car as they make wiring harness adapters to fit every thing in your car.
Before you install your head unit, go to Best Buy, or any car audio place, or on the internet and get a harness to suit the install. For instance if you have a pioneer head unit, and a 2007 Honda, you want a pioneer to 07 Honda wiring harness. This will allow your head unit to connect right into the stock wiring harness.
The same can be done for the speakers as well.
on Jan 01, 2010 | Car Audio & Video
Diagram abot wire harness
A wiring harness for the unit is most likely more than you would pay for a used unit at a pawn shop. Most sony receivers have the terminals labeled on the circuit board. If you are lucky, you can find a dead one at a stereo shop or repair shop near you. They didn't name them explode for nothing. Be careful. 25312832-wng3opgl1pug32fsc4t4fc4i-2-0.jpg
Dec 08, 2014 | Sony XPLOD CDX-GT200 CD Player
I have this model of Head units. I have used crimp connects to connect the unit harness to the car harness. Hooked up my turn on wires and rca cables. Now my head unit when turned on shorts in and out and...
For starters, I want to make sure. You did purchase a wiring harness that "plugs" into your vehicle, right? If not and you are attempting to hardwire to your vehicle, STOP! You run the risk of frying your entire electrical system. If you purchased a harness you can crip the wires from your head unit to the harness and the harness plugs in. DO NOT crip wires directly. You are experiencing just a little of what can happen. However, if you did purchase the correct harness, you need to check all our crimps again. Hope this helps.
Aug 21, 2011 | Car Audio & Video
I need to know witch wires go into witch hole on a vrcd400-sdu head unit there is 16 holes total on the back of the wiring harness
you don't stick wires in the holes. they make a male harness for the female harness you're messing with. your radio should have a harness that plugs into it with wires connected to it. then you buy the install harness for your year, make, and model car along with a dash kit if needed. then you proceed to connect the color coded wires from the head unit harness to the install harness you bought WITH CRIMP CONNECTORS. not packing tape or shrink wrap or any other thing you can think of to insulate the bare wires. crimp caps or **** connectors with electrical tape works fine.
Mar 17, 2010 | Car Audio & Video
Need help installing electric trailer brake controller
easiest way is to also buy the wiring adapter almost all elect brake units sell a vehicle specific wire harness that u unplug brake wire harness plug in other harness than plug in brake harness and just connect the wires to elect brake controller eliminates cutting and splicing ur brake harness about $18
Oct 25, 2009 | 1999 GMC Savana
The screen comes up with F 11 and will not spin at all
HI, this is a Serial communication error. This issue will more than likely concern the wiring harness.
The Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.((Usually the wiring harness will need to be replaced))
Aug 04, 2009 | Whirlpool Washing Machines
Need to find a wiring harness
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
Jul 24, 2009 | Car Audio & Video
Im puttin a new head unit with a different wire harness, i know what all the wires are on that wire harness, but with the 92 accord stereo wire harness i need to know which wires are speaker, remote, power...
You can buy a cheap harness from the local parts store for your Honda made specifically to put in aftermarket head units. Since you know the pin outs on your head unit, you can wire it up quickly uning this harness and it will plug directly into the factory Honda harness. Go to Scosche dot com part lookup for your number - I think the wiring schematic is on the outside of the package, too.
Apr 14, 2009 | 1992 Honda Accord
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Jensen VM9510 Car DVD Player Logo
22 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
