Question about Nokia 3110 Cellular Phone
My nokia 3110c does'nt turn on ,it swiched off while i was downloading a video,from that time it turned off and now does'nt work at all
  • 21 Answers
it's a software complaint . it can be solved by reinstalling the phone's software from authorised nokia service centers . it will solve problem.
Posted on Mar 23, 2011
My nokia 3110c could'nt start when it is switched
First try to reboot 3-6 times, even the problem persist you need to flash the phone.So, Click here1 if you want to do it by yourself or you can contact mobile repairing shop.And here is your flash file 3110c file.If you need further assistant leave a comment or testimonial.Thanks for visiting fixya
Mar 26, 2012 | Nokia Cell Phones
Nokia 3110c Software to Turn on phone.
Here is the solution
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 07, 2011 | Nokia 3110 Cellular Phone
I have Nokia 3110c the problem is battery is full but i Swich on the fone 2 or 3 time blinking and turn off
if it helps vote itfollow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps vote it
Jan 16, 2011 | Nokia 3110 Cellular Phone
Nokia 6500S turns of every 1-2 seconds. How can i format memory?
first of all you should replace your mobile battry .if problem d 'nt solve then press * 3 , power on button and menu button at same time.first press * with 3 with menu with power on swich
Apr 11, 2010 | Nokia 6500 Slide Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Restart my nokia 3110c automatically
hi,restart my nokia 3110c automaticly 3 times and then swich off.what is the rision send me solution.
Sep 10, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
