Question about Kenmore 24032\24036 Top Load Washer
My 12 year old Kenmore makes some incredible banging noise while in the spin cycle. It sounds like there are huge metal blocks spinng in it. My husband replaced the coupler and the dog ears because it was not spinning out the clothes. Now the spin cycle works but the babging is still there. What can it be?
    Sergeant:
    Champion:
  • 202 Answers
You need a new spin tube.. Their is no way to stop the sound without replacing the spin tube
Posted on Mar 22, 2011
Kenmore 400 make loud banging noise at end of the spin cycle
It sounds like the drive block may be stripped out. To check it, you will need to remove the agitator to see if it is bad. Below is a video to show you how to access the drive block. Here is the part to order if you should find it bad.
If the drive block is good, post back to me and we will continue the diagnostics on the unit.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | Washing Machines
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
Bangs when spin cycle is going
sounds like the washer is not level, underneath the washer are 4 legs that are adjustable, you just turn them up or down. one of them may be to high.
Jan 15, 2012 | Kenmore Washing Machines
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Refrigerator makes lot of noise
titu, can you be more specific on what kind of noise you're hearing. If it's a squealing noise I would suspect either the evaporator or condensor fan. See if you can isolate where it's coming from. Catriver..post back.
Oct 12, 2006 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore 24032\24036 Top Load Washer Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
