Question about Roomba Vacuums
My roomba charges, but when I turn it on to work, it starts then just stops. The light is green then turned red immediately. Battery??. No beeps whatsoever. please respond to snowbird321@hotmail.com
  • 4,350 Answers
Go to their website, they have diagnostics available to help you... http://homesupport.irobot.com/app/home.
Posted on Mar 22, 2011
    New Friend:
  • 8 Answers
Might need to replace your battery this is very common
Posted on Jun 12, 2013
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
My roomba mounts up to the charger the light blinks red then after a time it goes green but when I dismount it and push the green button it immediately goes red. It doesn't beep or do anything. It is that...
You have dead nimh (nickle metal hydride) batteries. You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Feb 07, 2010 | iRobot Roomba 560 Robotic Vacuum
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
925 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
