Question about Refrigerators
I have a GE model #GBSCOHCXCRWW serial #FT303448 refrigerator and the handle for the top(fridge part) slowing worked its way off. Its looks like i need a special tool to reatach it, if so where would i get this tool, if not how do i reatach it. please help, thank you
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Posted on Jun 24, 2008
mikedurland
  • 481 Answers
SOURCE: Loose Handle
the screws are sometimes hidden by a metal or plastic trim. you can take the trim off with a butter knife (usually).
Posted on Jun 29, 2008
freetek
  • 5568 Answers
SOURCE: Refrigerator warm
I think the defrost timer has failed, leaving the heating element permanently on. Probably won't start a fire but it needs to be either disconnected or replaced. If you are lucky, it may be located behind the lower grill.   If you have a Johnstone Supply outlet in your area, you can save a good bit of money if they stock them. It appeals to the service trade but will sell to anyone.
Posted on Sep 24, 2008
aborcass
  • 2651 Answers
SOURCE: refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
12-14 yr old ge bottom freezer. freezer is working, fridge is warm.
not all refrigerators are the same can you look inside the fresh food section around the door or on the back of the refrigerator and provide a model number?
Appliance 911 Sea Breeze
Sep 30, 2015 | GE Refrigerators
GE Ice maker works makes ice! continues to eject ice when glass is pulled away
the button behind the pad is stuck,bad model number,if it's a side by side open the fridge door.look up on top and on right wall and you'll see a tag with model and serial number
Oct 12, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
LEAKING FRIDGE
A magnitude of problems could be caused by this, you should really call someone to come out and look at the refrigerator. With that model having a ice maker and water dispenser, it could be a crack in the water filtration which is typically located in the lower read of the refrigerator. If nothing else seems to be wet on the inside of the refrigerator you can almost guarantee that its the filter and pump in the back leaking which will require a skilled professional to look at it.
Dec 08, 2011 | GE Refrigerators
Model # - CTX16CPCR LF752813 - Serial number Its leaking water from the freezer into the fridge...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | GE PTS22SCRBS Top Freezer Refrigerator...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
I have a GE Profile refrigerator, the top part is not working. The bottom freezer is still working. Model is PFFS22SBSBSS. Serial SL047242. Can you help.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 13, 2010 | GE Refrigerators
ISO refrigerator door handle
Your original repairman must have looked up a similar model without the snack door. The handle of couse would have also been listed, but this is difficult since A. You do not give your model number and B. (maybe not as bad) we don't know what model number he used when he ordered your door(s). Please list the complete model number of your refrig. (from sticker inside fresh food compartment) and I'll try to help.
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Oct 18, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
