Hi, this could be virus and it could be that the memory space on the phone is too small for the activities you want to perform.
solutions i think could help..
1. try delete some things you downloaded to the phone and memory card space...
2.try scan your phone for virus
after you have tried this two method and you still can't get the needed answer, you could try factory reset.
please note, factory reset will remove everthing you had on the phone.
cheers
Nokia 5220 xpressmusic contact service problem
First download and install
Pheonix from this link. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link 5220 file and install it to C / program
files/pheonix.. after finished this installation open pheonix . Inside the
interface at the> top left
<there you see "File" click there and choose "open
file" and then select the approprait Product type i.e
"which is written on the back panel inside the battery of every Nokia(Type
RM-000).After doing this again at the left top count from
"File"1..2..3..the 4th one is "Flashing" press there,
when you click there you'll see three sub-menus, just select the "Firmware
Update" again you'll see another interface. Look at the product code
there should be blank and put your "mouse tool" at the straight end
from the "Product Code" there is a Button and
choose the code which is written in the back side of your phone. e.g CODE:0000000.if
the same code does not found just take one which is higher. After this you can
see "Dead phone USB flashing" click that box. Now this is the
last stage... Connect your phone with the USB to your PC and let
the driver install ...wait for a moment.(If
your phone working).Lastly after just finished (In case your
phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
button after this, a message will prompt you "press power botton"
etc. insert charger or press it and wait
until the phone will Restart automatically in normal mode 10-15 minutes. If you
cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good
luck.
The phone is hanging up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
