Question about Field and Stream Field & Stream Hidden Compass Watch #F25SLUMI
Hello, I was gifted a field and stream f12pkt watch/compass. The glass on the compass is cracked and the batteries need to be replaced. Can you provide service to get this watch running again?
2 Suggested Answers
SOURCE: Compass dial turned opposite direction
atomic watch from field & stream, cant set the time and it resets itself 2 and a half hours off. a local jeweler replaced and tried to reset it.
Posted on Mar 13, 2011
Watch has film inside the glass. Also, the finish has began to decay in appearance.
The film is from moisture getting into your watch. Moisture can get in one of 3 ways generally. The crystal if cracked, the crown, or the back. In your case since you have buttons for the mulch-functions of the watch you add a possible place for moisture to enter. Take the watch to a watchmaker or watch repair person. Your watch has to be taken out of the case and the case needs to be cleaned. Next the watch tec. may be able to see just where the seals failed and replace them. We of course do this. Also if the gasket is old or out of shape this is a culprit as well.
Hope this helps, gabe
Aug 28, 2013 | Field and Stream F25SLUMI Wrist Watch
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Missing screw to hold band together need replacement
Most jewelry stores--or even jewelry counters in department and discount stores like Walmart--keep a supply of replacement screws for when one is lost while changing a watch band. Ask around, show them your watch, and you may even get the right screw for free!
May 06, 2011 | Field and Stream F187GWBS e by Field &...
Hi on my field&stream F196gkbs the sweep
This is an early warning sign to get the battery changed .The watch should still keep time for a couple of weeks.
Jul 14, 2010 | Field and Stream Field & Stream Explorer...
Changed battery and cant get cover back on. Whats the trick?
mcdevito75 here, Look for any matching Slot or groove or tab in the cover and the caseing. Example, there may be a small cutout in the cover for the stem, make sure it"s lined up, place the watch on a flat sturdy surface crystal (glass) up with even, even pressure from the palm of your hand press down Evenly and the cover should snap shut, if not, see a small watch repair shop in your area for help.
Jun 24, 2010 | Field and Stream F16PKT Pocket Watch
What kind of battery does the watch need?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 20, 2010 | Field and Stream F13PKTPK Pocketwatch
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
Need replacement strap for F33FOBGKVK
Try these guys; http://www.wristwatch.com/contact.aspx They sell most of the new Field and stream models and should hopefully be able to help Hope this helps, please post again if not :)
Mar 12, 2007 | Field and Stream F61GD Wrist Watch
Field & Stream Mens Watch, F42GUBS
Take the watch to a jeweller. They should have all the batteries and seals and tools necessary for the job, and it rarely takes long or costs that much. you could probably manage yourself, but getting the seals especially is easiest through a jeweller anyway. Most likely reason for any watch to be not working is the battery, the next would be moisture inside - normally visible round the screen/face. always worth replacing the battery to see, unless the watch cost less than the battery, which it didn't. Hope this helps :)
Jan 25, 2007 | Field and Stream Magnum F42GUBS Wrist...
Field and Stream Field & Stream Hidden Compass Watch #F25SLUMI Logo
Top Field and Stream Watches Experts
Joe Ball
Joe Ball
Are you a Field and Stream Watch Expert? Answer questions, earn points and help others
