Question about Linksys Computers & Internet
Computer downstairs has no wireless nic but have extra wireless router (Linksys 2.4 ghz) How do i configure the downstairs router to act as a wireless nic and connect to the upstairs router?
  • chase_staple Dec 07, 2011
    different situation, same solution though. I ended up finding the software download and converted the original wireless router into a bridge. Works well with slightly older linksys products.
    Novelist:
  • 147 Answers
I've had the same problem and this is how I solved it.
I followed this guide on creating a wireless bridge. You can either look at that page and/or follow my advice here.
1. Your primary router just needs to be a wireless router of any brand and model.
2. The router you have downstairs needs to be compatible with DD-WRT firmware. Check here on the DD-WRT website to see if your Linksys is compatible. If it isn't compatible, then either buy a router that is compatible or disregard this solution.
3. After finding your router on the DD-WRT router database page click on the router, and then click on "Mini generic" or "Standard generic" to download the firmware and save to Desktop.
4. See the installation guide at the DD-WRT wiki in order to install DD-WRT firmware. Scroll down to "Method 1: Flashing with Web GUI." The instructions are too specific and complicated for me to post here. Follow the instructions EXACTLY!
5. Now that DD-WRT firmware is installed go to Control Panel/Network Connections/Local Area Connection/Properties. Scroll down to Internet Protocol (TCP/IP) and click Properties. Now click Use the Following IP Address and enter
192.168.1.2 as the IP,
255.255.255.0 as the Subnet Mask, and
192.168.1.1 as the Default Gateway.
6. Open your web browser (Internet Explorer, Firefox etc.) and enter "192.168.1.1". The default login is root and password is admin.
7. Click Setup/Basic Setup. Scroll down to Network Address Server Settings (DHCP). Click to disable DHCP. This will prevent the bridged router from assigning addresses, which will be the function of the primary router.
8. Click Wireless/Basic Settings. For Wireless Mode select "Client Bridge." Select "Mixed" for Wireless Network Mode.
9. Click Wireless/Wireless Security. For Security Mode, select the appropriate choice that matches your primary router - either none, WEP, WPA or WPA2 and fill in the appropriate password etc. Make sure this matches exactly or the bridge won't work.
10. Click Status/Wireless. Scroll down to the bottom of the page and you'll see a button labeled "Site Survey." You now need to associate this router to your primary router to create the bridge.
11. Click the Site Survey button, and a window pops up showing available wireless networks.
12. Select "Join" on the SSID that matches your primary router. Close your web browser.
13. Go to Control Panel/Network Connections/Local Area Connection/Properties. Scroll down to Internet Protocol (TCP/IP) and click Properties. Select "Obtain IP Address Automatically".
14. Unplug network cable, wait 15 seconds, and plug cable back in. Wait another 15-30 seconds and test the bridge by attempting to connect to the internet from your downstairs computer. If it connects to the internet, then congratulations you've successfully setup a wireless bridge!
If it doesn't work:
1. Disable wireless security on your primary router temporarily and then select none for step 9 on your bridged router.
2. Make sure MAC filtering is disabled on your primary router.
Good luck and thanks for using FixYa. Please post back if you have questions.
Posted on Mar 22, 2011
  • Peter Calhoun
    Peter Calhoun Mar 22, 2011
    You do have to connect to your bridged (secondary) router with an ethernet cable that runs from your downstairs computer to the router.
  • 4,349 Answers
The router does not work that way, get a wireless card, or wireless USB for the downstairs computer.
Linksys wirelessg 2.4 ghz broadband router hook up and runwires, willnot work wireless
The wireless card in your computer may not be configured with the Linksys wireless settings.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 21, 2012 | Linksys Wireless-G WRT54G Router
Signal is not strong enough to connect laptop downstairs away from Linksys 2.4 ghz wireless router in my home network. I have ethernet downstairs, can I attach another wireless router, as well as my PC to...
Looking at the specs for that Linksys router, it is a "G" size router. Most "G" routers only have an average indoor range of 150 ft. and that also depends on what type of construction materials are in the home that could hinder that range and the signal. Another router attached would only degrade the signal even more, that is not recommended. A stronger ranged router would probably be a better solution, possibly an "N" or "N+". Hope that helps.
Jan 22, 2011 | Computers & Internet
Will any Wireless Adapters work without the PC's NIC?
Yes even without any NIC card installed on your computer , the wireless adapter will definitely work since its a different device that work for wireless connection and has nothing to do with your NIC card configuration.
May 15, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Lan 4pc by nic card
You can simply use or buy a router. Router will automatically network your computers without any special configuration.
Dec 17, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Computers & Internet Logo
360 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
